input shaft on my T45 trans is damaged - replacement options?
Old 06-24-2013, 08:55 AM
kingrukus
kingrukus's Avatar
Default input shaft on my T45 trans is damaged - replacement options?
The input shaft on my T45 transmission is damaged with a very slight bend. Is there any options for replacement?
I am hearing that the input shaft on the older 96-98 T45 transmission wouldn't work - is this true?
Also is it better that I just swap the entire transmission? The labor involved to replace just the input shaft seems quite high (about 5-6 hours)?
The transmission is already dropped from the car, as the clutch was being replaced. The mechanic is unable to slide the input shaft back into the clutch and says it is slightly bent.
kingrukus is offline
Old 06-24-2013, 12:24 PM
uberstang1
Chupacabra
uberstang1's Avatar
can always go with a 26 spline input but youll need to change your clutch disk as well. Can find a used t45 for rather cheap
uberstang1 is offline
Old 06-24-2013, 04:02 PM
kingrukus
kingrukus's Avatar
The mechanic said it would be about 5+ hours of labor to replace the input shaft on the current transmission, so I figured for the cost of labor and the cost of parts, I decided to go with a used T45 transmission and just swap the trannys. I found one locally with about 115k km (72k miles) for $600. Not sure if that was a good deal, but hopefully there isn't anymore issues...
Old 06-24-2013, 04:30 PM
Seabee1993
Seabee1993's Avatar
Try the T45source.com, their street/strip rebuild is about 1175.00, since your Trans is out, you ship it to them, they rebuild it and send it back to you.
Seabee1993 is offline
djbigskrilla
09-20-2022 01:04 AM
Jskeezy84
09-08-2015 01:40 AM
chain
08-17-2015 08:52 AM
Boostaddict
Lethal Performance
08-13-2015 01:57 PM
Mnuckolls
08-09-2015 08:54 AM
Quick Reply: input shaft on my T45 trans is damaged - replacement options?
