Washed motor now serious miss
Old 06-30-2013, 08:09 PM
Slngshott
Slngshott's Avatar
Thanks everyone for the suggestions . Gonna pull the boots and blow everything dry. Do I need to remove the fuel rail to remove the cop's, ive seen a you tube video where the guypulls the fuel rail to remove the cop's. is this the way or can i get them out without pulling the fuel rails off.I probably gonna change the plugs while I have the packs off. I never had this problem with a vehicle before. I was down my Tahoe's motor from mud and dirt and never had an issue.
Slngshott is offline
Old 06-30-2013, 08:34 PM
DJINN n TONIC
DJINN n TONIC's Avatar
No, the rails stay where they are. Remove the (I think 7mm) bolts from each coil, gently twist to break the seal, and lift. when they reach the rail, you will be able to "Flex" the plug boot and wiggle it out. DONT TUG ON IT.
If you have access to compressed air, by all means blow the tubes out BEFORE removing the plugs. If not, As I told you before, with the plugs out, crank the motor over for a few seconds and all the junk in the tubes will get blown out.
Just remember....Lesson learned....
DJINN n TONIC is offline
Old 06-30-2013, 10:41 PM
JJ Glo
JJ Glo's Avatar
Be careful with the plugs if you change them. If you have a torque wrench, I believe it's 11-14 lbs? If not, 1/8th turn after hand tightening.
JJ Glo is offline
Old 07-01-2013, 12:18 AM
Sonic Mustang
Banned
Sonic Mustang's Avatar
That should be 1/16th of a turn.
http://www.ngk-sparkplugs.jp/english...q18/index.html
Sonic Mustang is offline
Old 07-01-2013, 12:22 AM
Sonic Mustang
Banned
If you have trouble telling them apart, remember one has two doors.
Old 07-01-2013, 06:39 AM
uberstang1
Chupacabra
uberstang1's Avatar
If u don't have a compressor u can just buy a can of compressed air.
uberstang1 is offline
Old 07-02-2013, 04:55 PM
Slngshott
Slngshott's Avatar
Thank you everyone for the help and the smart *** comments that had me laughing. I do 99% of my own work so yes I am mechanically inclined. Here is what it was. I replaced all the plugs which got rid of my check engine light and misfire on cylinder 2. I then had a popping sound in the exhaust and car would stumble so I purchased a new coil from napa and replaced the #2 cylinder coil that I had the misfire on and it runs great now. Now to spend some $$ and replace the rest. If ones going the rest have been used just as long so they most likely gonna go to. Thanks again for all the help
Old 07-03-2013, 08:12 AM
j-town_edge
j-town_edge's Avatar
Gald to hear you got the coil swapped and it's running again. FWIW, you can wash motors, but you never know what might happen. I've known plenty of guys that do that to their rides and have never had issues doing so. That being said, spraying pressurized water onto/near electrical components (no matter how good they're supposed to be sealed) is a gamble at best.
j-town_edge is offline
Old 07-08-2013, 12:46 PM
Saabonthis
Saabonthis's Avatar
This happens to me every time I go through a car wash. Misfires for awhile then clears up.
Saabonthis is offline
lovesilver
Members Mustangs
05-09-2019 09:18 PM
Matt's 95 Stang
10-05-2015 07:16 AM
Dathan
10-05-2015 05:52 AM
logan409
09-26-2015 07:43 PM
ThatJuanStang
09-25-2015 08:01 AM
Quick Reply: Washed motor now serious miss
