Speedo gear swap
Old 02-27-2014, 09:43 PM
TRAVIS87
TRAVIS87's Avatar
Default Speedo gear swap
Gonna be swapping 3.73's into my car with the help of a friend with a lift. Wondering if anyone has any info or write up on doing the speedo gear swap. I've got the T-5 trans and from what I've heard the tail-shaft housing can be removed to swap the gears. The problem is I haven't heard if the trans has to be pulled or left in the car. Any info would be sweet!
Thanks guys!
TRAVIS87 is offline
Old 03-08-2014, 10:47 PM
TRAVIS87
TRAVIS87's Avatar
Bumpppp!!!! Anything guys?
TRAVIS87 is offline
Old 03-09-2014, 07:23 PM
WJL
WJL's Avatar
American Muscle has a write up
WJL is offline
Old 03-10-2014, 11:04 AM
tracyballard
tracyballard's Avatar
I don't think there is a gear available that is sufficient to make that much of an adjustment, you have to go with speedcal or a tuner.
tracyballard is offline
Old 03-11-2014, 10:17 AM
AMDanBailer
Former Sponsor
AMDanBailer's Avatar
Thanks guys!
Hey,
Unfortunately you will need to take the trans out of the car in order to install a new speedometer drive gear. Attached here is an installation guide on how to do the complete install. If you are not already aware, to correct the speedometer, you will need a 7 tooth speedometer drive gear combined with a 21 tooth speedometer gear.
I hope this helps, and if you have any other questions, feel free to get in touch with myself, or our customer service department. Good luck!
-Dan
AMDanBailer is offline
musnicki
09-23-2015 07:11 AM
jaiidutch
09-14-2015 10:29 AM
Ryan Fitzpatrick
09-14-2015 02:21 AM
Pyrate Dave
09-10-2015 07:30 PM
vintageaion
09-08-2015 10:45 AM
Quick Reply: Speedo gear swap
