possible head gasket question
Old 03-02-2014, 10:58 PM
saleen coupe
saleen coupe's Avatar
Default possible head gasket question
I bought a 03 cobra a couple of months ago and i now notice when i start it up there is alot of white smoke that gets better when the car is warmed up, but when i first start it if i rev the engine it will puff lots of white smoke, i first thought it was just condensation but i'm getting worried about it. Now, i have no water in the oil and my coolant was just a little low but its now really getting any lower, after i first got the car i did notice it dripped some coolant on the ground but that was the only time it has ever done it and i never did find the leak,what do you guys think of this situation? also meant to add that the car idling the temp will get to 200 then the fans come on but at hwy speeds the car runs anywhere from 135 to 155 degrees.
saleen coupe is offline
Old 03-03-2014, 08:16 AM
school boy
school boy's Avatar
if you have an off road mid pipe you will get a little white smoke at idle but with you revving it and getting more has me concerned
school boy is offline
Old 03-03-2014, 08:51 AM
saleen coupe
i do have an o/r x pipe, once the car has warmed up or after a short drive it will not do it, I don't have any real reason that it could be a head gasket except for the smoke, there is no overheating or coolant in the oil. I hope i'm just being paranoid but i'm keeping my eye on the coolant too see if its loosing any. Is there anything else I can do to test the gasket?
Old 03-03-2014, 04:52 PM
school boy
school boy's Avatar
A compression test, both with engine warm and cold. If a cylinder is way off from the others then a gasket may be the problem.
10-26-2015 05:01 PM
Luke9222
10-22-2015 11:55 PM
cbird1177711
09-02-2015 08:51 PM
cbird1177711
09-02-2015 04:12 PM
Quick Reply: possible head gasket question
