no fuel (pump not working)
Old 03-23-2014, 02:25 PM
Shampue
Shampue's Avatar
Default no fuel (pump not working)
Hello
Having trouble with my 01 GT.
There appears to be no fuel getting to the motor. With the key set to on, I get no fuel out the value on the fuel rail. Also, I do not hear the pump prime.
The fuse in the engine compartment is good (or at least looks good)
Can anyone shed some light on this or give me some suggestions on what else to look for?
Thank you
Shampue is offline
Old 03-23-2014, 06:07 PM
edwin108
edwin108's Avatar
Did you check if the inertia switch was tripped?
edwin108 is offline
Old 03-23-2014, 06:16 PM
Shampue
Shampue's Avatar
Yepper. It wasn't. I'm almost certain its the fuel pump. Its still so freaking cold here in Wisconsin I may try to take my mind off it till its warm enough to deal with
Shampue is offline
Old 03-23-2014, 07:08 PM
edwin108
edwin108's Avatar
Check out this thread, it has some wiring diagrams that you could use for troubleshooting.
edwin108 is offline
Old 03-24-2014, 01:41 PM
Shampue
Shampue's Avatar
Thanks, yeah I came across that thread after I posted. I appreciate the help. I'll post results when I am able to
Shampue is offline
Old 03-24-2014, 02:19 PM
Derf00
Gentleman's Relish
Derf00's Avatar
Pop the back seat out, find the connector for the fuel pump and direct wire it to a 12V source. If it fires up then it's not the pump and you'll have to trace it back.
If it's not the pump, the fuse is good and the inertia switch isn't tripped I'm going to go with a bad Fuel Pump Relay. You can test those too.
Derf00 is offline
Old 04-01-2014, 10:44 AM
Shampue
Shampue's Avatar
I'm looking at fuel pumps on Rockauto. They range from $40 to $400. Anyone suggest a quality replacement?
Thank you much
Shampue is offline
Design1795
01-24-2017 10:38 PM
Design1795
08-24-2015 04:41 PM
1999350m
08-24-2015 07:06 AM
drumhedd2005
08-13-2015 09:59 AM
89blueslug
08-10-2015 07:20 AM
Quick Reply: no fuel (pump not working)
