Instrument cluster lights
Old 06-20-2014, 12:04 AM
heavydem
heavydem's Avatar
Default Instrument cluster lights
Hi all. I have a 2003 GT conv. My dash lights don't work. I have checked all fuses and they are fine. Anyone have a tip ? I know I should trace the wires but just curious if there is another fuse that may control it ? Thanks everyone.
Cheers
heavy
heavydem is offline
Old 02-27-2015, 10:39 AM
v8sn95
v8sn95's Avatar
I have the same problem, I have read that if all fuses are fine then it could be the dimmer switch itself....or trace it to the gauge cluster harnesses, they could be loose. Thats all that i can say, until i take mine apart today and look at mine. Good Luck. If you found the problem please respond with your solution.
v8sn95 is offline
Old 03-08-2015, 11:40 PM
xoHollieNicole
xoHollieNicole's Avatar
I had the same problem! Try replacing your dimmer switch! It fixed mine. =]
xoHollieNicole is offline
Old 03-09-2015, 08:24 AM
v8sn95
v8sn95's Avatar
My new dimmer switch arrived Saturday, I just gotta find time to install it. I had driving home at night and all of a sudden my gauge lights turn off
v8sn95 is offline
Old 03-14-2015, 01:32 PM
v8sn95
v8sn95's Avatar
So update, I replaced the dimmer switch....Still didnt resolve it..however after taking out the gauge cluster / instrument panel from the dash. I noticed two wires that went from the circuit board into the cluster. A "red and black" wire, and touching the wires, i noticed the gauge lights would flicker on and off. So i removed the gauge cluster from the dash, took it inside, removed the wide panel that is attached to the back and cleaned it with a damp towel, then drying the whole thing off with another DRY cloth. Using electrical tape, pressing firmly to tape down the wires to the plastic panel, (not the circuit board). And replacing the white back panel, hooked everything back up.....PROBLEM SOLVED. I hope this helps! Now moving onto other projects.
v8sn95 is offline
jwog666
12-27-2021 08:09 PM
4cylinderplus2
10-09-2020 07:45 PM
lincolnshibuya
12-08-2015 04:37 PM
Matt's 95 Stang
10-05-2015 07:16 AM
ChampInSD
10-02-2015 04:55 AM
Quick Reply: Instrument cluster lights
