Leaking Rear Differential
Old 07-28-2015, 04:13 PM
MasterLanMan
MasterLanMan's Avatar
Default Leaking Rear Differential
Let's just start off this thread with the truth.
I ****ed up.
I used the rear differential to jack my car up and ended up bending the rear differential cover and fluid is slowly leaking out. This isn't all bad, because I should replace that POS aluminum cover with something more sturdy and I'm installing 4.10 gears anyway. What I am wondering is if the cover is just allowing the fluid to leak? Or is it the pinion seal as well? Any help at all would be greatly appreciated!
MasterLanMan is offline
Old 07-28-2015, 06:24 PM
Camster
Camster's Avatar
It should be just the cover.
It should be obvious where the leak is originating.
I think that the oem cover is steel.
Camster is offline
Old 07-29-2015, 05:50 PM
Ashton_1012
Ashton_1012's Avatar
hey man... you could have f***ed up even more. That funny differential noise i had turned into a destroyed rear end the other day!
Anyways- as camster said, it should just be the cover. you would have to really screw up to damage your pinion seal with a jack on the differential. Really easy to see as well, look where the driveline goes into the differential. If its leaking, it needs replacing.
Ashton_1012 is offline
Old 07-29-2015, 07:59 PM
MasterLanMan
Here is a picture of the rear differential cover. Any thoughts?
Old 07-29-2015, 11:32 PM
jwog666
jwog666's Avatar
just replace the cover with a stock type replacement, this is not a big deal
jwog666 is offline
Old 07-30-2015, 07:41 AM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
this
those fancy girdle type covers wont keep your rear from exploding any faster or slower.
find a stock one for a couple bucks and slap it on there when you do gears. Also, throw away that stupid paper gasket they give you for the cover, and use a nice solid bead of RTV
WhiteFoxGT is offline
Old 08-02-2015, 08:17 PM
JonnyBlazeGT
JonnyBlazeGT's Avatar
I bought a girdle style cover for mine when I had the 3.73's installed. I like the convenience of having a drain plug.
JonnyBlazeGT is offline
mtgldr
02-03-2024 09:00 PM
Ryan Fitzpatrick
09-14-2015 02:21 AM
MusicCity615
09-12-2015 07:05 AM
09-08-2015 11:50 AM
Quick Reply: Leaking Rear Differential
