3.8 liter 2000 Mustang engine trouble
Old 03-19-2016, 04:23 PM
Mccourry1400
Mccourry1400's Avatar
Default 3.8 liter 2000 Mustang engine trouble
Hello I'm new I don't want to make a rlly big post so its gonna be to the point my engine runs fine but it won't rev past about 2500 rpm on a good day what could be the cause it throws a code of P1413 low circuit any tips would help
Mccourry1400 is offline
Old 03-19-2016, 05:01 PM
Chromeshadow
Chromeshadow's Avatar
It may be the smog pump, I had to replace mine at about 150K miles. It is pretty easy to take out and take apart, they usually fill up with water and rust up so they don't run.
Chromeshadow is offline
Old 03-19-2016, 05:06 PM
Mccourry1400
How did ur car act when your smog pump went out ?
Old 03-19-2016, 07:11 PM
Chromeshadow
Mine ran fine-just got the error code. Some people have had to replace the O2 sensors as well.
It's pretty easy to get to- to check it out...Give yourself 30 minutes or so. You might be able to reach it and put your hand on it, there is a motor inside that froze up on mine, I could tell the motor wasn't running when I put my hand on it. These only run about 30 seconds when you start the car.
Old 03-19-2016, 08:54 PM
dawson1112
dawson1112's Avatar
Clean your MAF. Change the fuel filter.
The P1413 isn't going to cause you to have drivability issues. It just means that you have a secondary air problem, could be a plugged hose or the hose came off.
dawson1112 is offline
Old 03-19-2016, 08:57 PM
Mccourry1400
Mine won't rev above 2500 rpm at all could it be a sensor on the throttle body
Old 03-20-2016, 07:59 AM
Mccourry1400
Have you had the same problem in the past? Or kno anyone that has had this problem
trackers
03-31-2016 02:29 PM
jgull1g
03-23-2016 01:49 PM
xNightFirex
03-17-2016 05:49 AM
Coyotefiveohh
03-17-2016 04:18 AM
Quick Reply: 3.8 liter 2000 Mustang engine trouble
