Fuel Pump Wiring for 1998 Mustang 4.6 SOHC
I am looking for a fuel pump/fuel sensor wiring diagram for a 1998 4.9 SOHC. I am putting the engine in a Factory Five Cobra and need to understand the fuel pump and associated parts wiring.
thanks.
Wade
thanks.
Wade
Do you mean a 4.6L. If the motor is out of a 98 Mustang it's a bastard year some have a return fuel system some have a non-return. So depending on what pump system you have obviously will depend on how it's wired.
All are wire through the ecu, CCRM, pump relay and a inertia shut off switch, some where on this form is a 2003 Mustang repair manual PDF it also has wiring diagrams, however it will be for a non return system
Good Luck
Good Luck
