2000 GT spun bearing
Old 04-27-2016, 06:57 PM
Agentorange00
Agentorange00's Avatar
Default 2000 GT spun bearing
I have a 2000 GT with 72k I bought it last summer and noticed the car knocking. Pulled the motor to find I had a spun bearing. I have been trying to decide what to do. Have been looking for a clean good running 4.6l to put in my car. But can't seem to find anything worth buying. Also found a few 3v motors but I am not 100% sure how much work it's going to be. I'd like to try and keep the price below $2000.00 thanks
Agentorange00 is offline
Old 04-27-2016, 10:36 PM
jwog666
jwog666's Avatar
a 3v swap is pointless as you dont gain much power for all the extra cost. if you are looking for a swap that is worth the extra money you would want to swap in a 5.0 out of an 11 and up mustang. both will cost alot and require a ton of work. you wont touch a reman or new shortblock for what you are budgeting, so your options are to set the bar a little lower and settle for a used engine, or save some more
jwog666 is offline
Old 04-28-2016, 11:44 AM
Camster
Camster's Avatar
jwog666,
Can the OP have his crank machined and install properly sized bearings?
Wouldn't that be his best and most economical option?
Camster is offline
Old 04-28-2016, 11:50 AM
jwog666
jwog666's Avatar
Originally Posted by Camster
jwog666,
if it spun a bearing, it also damaged the rod journals, so you would end up rebuilding the rotating assembly, and they you would check the bore to measure wear, and find it has some, so then you wold end up rebuilding the entire short block. not to mention that there is metal contamination in the oil passages due to the spun bearing which will require the block to be cleaned. so no, its not economical.
jwog666 is offline
Old 04-29-2016, 06:43 AM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
why cant he just spin the bearing back
WhiteFoxGT is offline
Old 04-29-2016, 10:35 AM
barstowpo
barstowpo's Avatar
If you can do the work yourself, machine work should be around $1500. Parts maybe $500 or so if nothing is too damaged to reuse. If there is too much cylinder wear, add another couple of hundred if you have to replace the pistons.
barstowpo is offline
Old 04-29-2016, 12:10 PM
movielover40
movielover40's Avatar
Junk yard motor would be your best bet.
movielover40 is offline
Old 04-29-2016, 12:24 PM
09GT/CS
09GT/CS's Avatar
Yeah for that budget range I would check around to places like LKQ and other scrapyards. I got a really good trans from LKQ a few years back and even got a 2 year warranty on it.
09GT/CS is offline
Old 04-29-2016, 12:52 PM
school boy
school boy's Avatar
I would 4v swap the car. A budget 4v swap can be done for $2000 pretty easy. I would find a 97-98 Mark viii pull out. Already has an intake manifold you can use, c.o.p valve covers which saves a chunk of funds.
school boy is offline
19stang88
01-12-2020 10:20 AM
sinskeep
04-24-2016 07:41 AM
Sandmanbjj
04-03-2016 10:01 AM
XForce USA
XForce-USA
03-30-2016 12:24 AM
Drastang
02-11-2016 12:21 PM
Quick Reply: 2000 GT spun bearing
