4.10 gears
Old 01-03-2004, 01:54 AM
RJM02GTDrag
RJM02GTDrag's Avatar
Default 4.10 gears
OK so everyone has pretty much convinced me to go with the 4.10 gears and put in a locker while we are at it. Questions- will this make the rear end durable enough tohandle slicks, or should I stay with drag radials at the track? What does the locker do to the traction control and the computer?
RJM02GTDrag is offline
Old 01-03-2004, 03:09 AM
BLKSTANG9879
BLKSTANG9879's Avatar
Default 4.10 gears
If you go with a Auburn Locker. You will be good well into the lower 10s. Your axles are another story.</P>
BLKSTANG9879 is offline
Old 01-04-2004, 01:54 AM
RJM02GTDrag
Default 4.10 gears
OK- so 4.10s and locker it is, what about the traction control and computer does that get by passed? Fine if it does I never use anyway but how does the locker affect handling on the back roads or is it exclusive to the strip, any replies would be appreciated?
Old 01-04-2004, 03:29 AM
lpstang
lpstang's Avatar
Default 4.10 gears
what is a locker?
lpstang is offline
Old 01-04-2004, 12:02 PM
BLKSTANG9879
Default 4.10 gears
A locker locks your rear. So both tires move at the same speed in a straight line. But when you turn. You know the thing the outside tire spins faster, cause it has more room to cover. So in the turn it unlocks. I hope this helps you under stand it a little better.
Thunderball
15
11-22-2015 11:49 PM
Bokeo
10-10-2015 08:28 PM
KingRando
10-02-2015 08:06 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
junior04
09-28-2015 10:53 AM
Quick Reply: 4.10 gears
