Need advice on drag suspension
Old 12-09-2005, 11:36 AM
XxphantomsnypzxX
XxphantomsnypzxX's Avatar
Default Need advice on drag suspension
I dont know much at all on drag suspensions all I know is the GT is better rear suspension than the Cobra Independant rear suspension, please gimme adivce for a drag suspension
XxphantomsnypzxX is offline
Old 12-09-2005, 11:41 AM
BCisme
BCisme's Avatar
Default RE: Need advice on drag suspension
well if you just want a few inexpensive mods to help your 60' ft times, a nice set of control arms will help your wheel hop, and some nice springs/struts. ( i think the rear is struts, i always forget)
if you want big stuff, you'll need a setup like i have. UPR QA1 kit, A-arms, K member, coilvers caster/camber etc... and a setup like i mentioned above. subframes wouldn't hurt either.
give us an idea of how much money you are looking to spend, and we can offer better advice. a full setup plus drag radials will set you back a few grand, or a few hundred bucks for a few basic parts to help you get moving a little quicker from a stop.
BCisme is offline
Old 12-09-2005, 01:16 PM
Tim37
Tim37's Avatar
a set of rear control arms is a must then a set of moroso trick springs all the way around and then a set of lake wood drag struts up forn and shocks toss the front sway bar keep the rear and that will be good for most street/strip apps.
its not really suspention but a set of subframe contectors will help.
Tim37 is offline
Lethaldosage423
10-19-2015 12:12 AM
Matt's 95 Stang
10-05-2015 07:16 AM
Florida Regional Chapter
09-30-2015 08:04 PM
guitarman376
09-30-2015 05:54 PM
marc954
09-29-2015 11:18 AM
Quick Reply: Need advice on drag suspension
