Mil eliminator?
Old 12-17-2005, 12:45 PM
wildazme
wildazme's Avatar
Default Mil eliminator?
Im trying to buy an xpipe for my stang, i was looking at the catted xpipes and i see they recommend mils eliminators to go with them. what exactly is a mil eliminator?
wildazme is offline
Old 12-17-2005, 01:00 PM
rustyshackle4d
rustyshackle4d's Avatar
Default RE: Mil eliminator?
it turns your check engine light off. if you are buying catted xpipe and there are spots to hook up your exhaust sensors you may not need a mil.
rustyshackle4d is offline
Old 12-18-2005, 08:48 AM
wildazme
wildazme's Avatar
so then let me ask what would be the since of getting a catted xpipe if its gonna set the check engine light off anyway? i mean thats what they use for 97 and up cars in ny when doing the smog test, they dont actually test the emissions anymore they just look for check engine codes.
wildazme is offline
Old 12-18-2005, 08:55 AM
rustyshackle4d
I don' know for sure if a catted xpipe will set off your check engine light. I have not got an x pipe yet but i am getting an off road xpipe because my mustang is no longer a daily driver. If i were going to have it as a daily driver, I would get the cats. Some brands of xpipes have spots to hook up your sensors and some don't. If they don't you need the mil's if they do have them i would assume that they are catted and they won't set off the check engine light. But maybe someone else here knows for sure?
Old 12-18-2005, 09:09 AM
sdsjr4
sdsjr4's Avatar
Ok a catted x-pipe has converters on them like the stock ones if you buy a catted one the only thing you need to do is bolt your 02 sensors back on the new pipe. The 02 sensors are already in place on your car. The only reason for mil's are to trick the computer to not throw a code and set the check engine light on!The reason for check engine light coming on is because with a off-road h or x pipe there's no converters which is illegal in most states to have! Hope i have helped
sdsjr4 is offline
Granatelli Sales
01-20-2020 12:34 AM
Scottyboy187
SVT Forums
11-20-2015 02:57 PM
Florida Regional Chapter
09-30-2015 08:04 PM
trashxtrash
09-20-2015 10:49 PM
09-17-2015 07:57 PM
Quick Reply: Mil eliminator?
