Mine didn't happen until the patriot heads. There's no swirl dam, so it my belief you need to run more timing or a leaner cruise af between 1500-3000. I see max boost around 6700.
Well I guess technically my AF is leaner at that range, but not by much.
I can't even remember since the last time I datalogged, but I do know it was leaner from 1400-3000RPM
That's probably your WOT tune. At cruise and partial throttle it's probably a lot leaner. That's when I get the slight hiccup I call it. It use to be worse were it would want to back fire a little also.
I think there's unspent fuel at these rpms at partial throttle when the swirl dam is missing. But I'm no tuner
Go add 2* of timing global and take it for a drive. Then come back and let me know how it worked out. If it works I'll do it.
I would do it now but I have my fuel system down and cleaning the filters. Damn hot weather is boiling my fuel and getting me vapor lock. Now I have to keep a full tank all the time until I can afford a pump speed controler.
Mine is 15.1-15.5 though out that rpm range at part throttle. At WOT it drops to 11.5 like its supposed to but still hesitates a bit. It's hard to tell since it runs through those rpms so fast at WOT.
