built t-45 or built 6 speed?
Old 10-22-2009, 06:23 AM
orange96gt
orange96gt's Avatar
Default built t-45 or built 6 speed?
Ok so i have the t45 with 3.27 gears and 580rwtq but the stock trans crapped out so i need to upgrade. Switching from 4th to 5th gear with the t45 the rpms drop a lot my question is if i were to get a t-56 would there still be a big jump from 4th to 5th? also having 3.27 gears would i even benefit from a six speed transmission? not set on t-56 just would like to know what would be best for my setup. any info is appreciated.
orange96gt is offline
Old 10-22-2009, 02:03 PM
5.0 85 GT
5.0 85 GT's Avatar
well...idk the 6spd i know is easier to bang it into 5th to keep the rpms up, but either way 5th is in a another H pattern so to speak, so ur gon alose a few rpms compared to the 1-4 gear bangin, but wont be as bad, because i too lose osme serious rpms in my t-45...and i would go witht he 6spd as well becuase you can add a steeper gear and still have the roms to cruise on the highway with the double OD
5.0 85 GT is offline
Old 10-22-2009, 02:26 PM
Tim99GT
Tim99GT's Avatar
well if you dont the like the big jump to 5th from 4th in the T-45, the T-56 will be what you want. The final gear ratio is the same(or so close you cant tell the difference) as the T-45, unless you get the Viper spec T-56. Basically the T-56 is the same as the T-45 with the exception of a extra gear that is placed in between the T-45's 4th and 5th gears. The T-56's 1st gear is taller though i believe. I wanna say the end gear ratio of the regular T-56 is like a .62 where as the viper spec is a .50 i believe.
Tim99GT is offline
Old 10-22-2009, 02:30 PM
Shotgun Love
Shotgun Love's Avatar
would something like that be an easy swap?
Shotgun Love is offline
Old 10-22-2009, 02:39 PM
Tim99GT
Tim99GT's Avatar
Its not that hard.
Here is the write up the Jazzer did awhile back on it:
https://mustangforums.com/forum/4-6-...tructions.html
Tim99GT is offline
lincolnshibuya
10-06-2015 08:45 AM
UrS4
10-03-2015 06:23 AM
BeatnikFink
10-01-2015 08:00 PM
1Bad71
09-30-2015 07:37 PM
Drastang
09-30-2015 03:48 AM
Quick Reply: built t-45 or built 6 speed?
