Comp XE268AH vs XE270AH
Old 11-26-2009, 01:41 PM
  #21
mrtstang
mrtstang's Avatar
Originally Posted by H0SS302
LOL...look who your talking to.. how many times have I said that?
Im just saying when you look at everyones numbers on here, those 268s have put out at least 5more HP to the wheels..
I guess anything can happen, but that's really weird that the 268's would do better. The 270's have more lift which = more power, more duiration which = more power, and a tighter lsa which = more power lol.
mrtstang is offline
Old 11-26-2009, 06:54 PM
  #22
mustangmancp
mustangmancp's Avatar
Alright this is really interesting to me...so what are you saying in the end? Would a Hitech stage 2 get more power then a 268? Cuz im looking into cams in the spring, and i want the most power i can get for the buck.
mustangmancp is offline
Old 11-26-2009, 07:20 PM
  #23
WannaBeGearHead
Go Texas!!!
WannaBeGearHead's Avatar
^^^ According to cam specs, like mrtstang said the 270 should be making more power than the 268 due to a larger lift and longer duration. When comparing the Hitech stage 2 cams and the 270, it seems the 270 would get you more power then the Hitech stage 2 cams again due to the larger lift and duration.
WannaBeGearHead is offline
Old 11-26-2009, 07:21 PM
  #24
H0SS302
H0SS302's Avatar
Yet they dont..
Its not all in the lift lol
H0SS302 is offline
Old 11-26-2009, 07:22 PM
  #25
H0SS302
H0SS302's Avatar
With full bolt ons hitech stage 2s regularly get 300 RWHP I have yet to see a 270 cam grind get into the 290s..
H0SS302 is offline
Old 11-26-2009, 07:23 PM
  #26
mustangmancp
Alright i know this...so from what you've observed what would i be better off getting for the most power??
EDIT: Sorry didn't see ur post lol. So hitech stage 2s. Thanks Hoss
Old 11-26-2009, 07:26 PM
  #27
WannaBeGearHead
Go Texas!!!
^^^ That is interesting. Do all the cam specs use the same scale to figure out lift, duration and LSA? I ask because according to SPECS, I would think the 270 makes more power due to the longer exhaust duration and lift (intake is the same).
There is a member in here that has the 270s and he makes 288rwhp with full exhaust, CAI and a dyno tune.
Old 11-26-2009, 09:02 PM
  #28
mrtstang
mrtstang's Avatar
The Hitechs will make more power on stock PI heads, because they address the intake side where the PI motor needs it. By keeping the specs down on the exhaust side, while maximizing intake side, it ensures that the already strong exhaust flow does get over scavanged. This is why the Hitechs are so sucessful.
So, even though the 270's look stronger on paper, they don't have it where it counts basically.
mrtstang is offline
Old 11-26-2009, 09:07 PM
  #29
WannaBeGearHead
Go Texas!!!
^^^ Ya I was wondering why people would say the Hitechs are better on the PI motor because they addressed the intake side when the 270s had the same intake duration and larger exhaust duration with a larger lift. But your explanation makes sense.
Old 11-26-2009, 09:09 PM
  #30
mrtstang
mrtstang's Avatar
The reason i said that the 270's should make more than the 268's is because even though both are basically very similar, the 270's have a better intake lift, and a better intake centerline.
mrtstang is offline
Quick Reply: Comp XE268AH vs XE270AH
