Question about verts and HPDE
Old 03-29-2010, 12:59 PM
AaRonin
AaRonin's Avatar
Question Question about verts and HPDE
I have yet to by a Mustang, but I'm looking for an SN95 to drive daily, maybe start taking to HPDE events, and the occasional drag. I'm familiar enough with drag and NHRA's leniency above 11.99, but part of me wants a convertible, since my last car was (01 MR2 Spyder). I know they're a bit heavier, and I know verts in general aren't known for their handling compared to their hard top counterparts. My question is will a bar like this: http://www.americanmuscle.com/cldecocoli9b1.html satisfy SCCA tech (and I guess NHRA guidelines as well, since I intend to be sub-13.49).
AaRonin is offline
Old 03-29-2010, 06:07 PM
sv650lex
sv650lex's Avatar
I would say probably not since it doesn't give you any rollover protection
sv650lex is offline
Old 03-29-2010, 06:52 PM
bopiela
bopiela's Avatar
No it does not. Those bars are not designed to protect you or provide any support in any way. They are strictly appearance mods. I know the companies that sell them typically have to mention or have small print somewhere saying they are not to be used in place of a rollbar or for safety purposes. You would need to get an actual roll cage.
bopiela is offline
Old 03-29-2010, 07:03 PM
ct_white_stang
ct_white_stang's Avatar
+1 on this one ^^^^. Although, it did feel like it tied the car together a bit for me.
ct_white_stang is offline
Old 03-29-2010, 07:42 PM
justag6969
justag6969's Avatar
a roll cage of a removable hardtop
justag6969 is offline
Old 03-29-2010, 08:14 PM
bopiela
bopiela's Avatar
ct - it will stiffen ur ride a little because it has a solid beam running through it that is bolted to your car. its essentially a sway bar for convertibles that are prettied up, haha. but that sway bar wont save your life!
bopiela is offline
Old 03-30-2010, 05:50 AM
jmac72187
corner carver
jmac72187's Avatar
You will want to run an actual roll bar. A removable hard top isn't going to do **** in a roll over. I have seen cars with removable hard tops roll on video and the roofs do not even last one roll.
With any club and HPDE's you are going to need a roll bar.
The vert while not ideal for the track will still be a fun car. If you are not trying to stay in class, make one of your first mods Full Length Subframe Connectors to reduce flex. The stock vert ones are a shorter weaker design.
jmac72187 is offline
Old 03-30-2010, 09:06 AM
teej281
4.6L Section Moderator
teej281's Avatar
I thought about trying to do a rollbar and have it painted either gold or true blue to match the car instead of a light bar...but i still dont know how i feel about that one.
teej281 is offline
Old 03-30-2010, 02:49 PM
AaRonin
AaRonin's Avatar
thanks for the info guys. I think I'm probably going to stick with a hard top.
AaRonin is offline
Old 03-30-2010, 09:28 PM
H0SS302
H0SS302's Avatar
I decided against a roll bar because I figure the windsheild is gonna buckle and cut my head off anyways.. so I went for style.
And plus 1 to what jmac said.
H0SS302 is offline
chrisdbassplayer
10-13-2015 06:53 PM
mungodrums
09-28-2015 10:54 PM
treesloth
09-28-2015 07:03 AM
12bigredstang
09-24-2015 10:43 AM
Quick Reply: Question about verts and HPDE
