Is there a turbo for the street cars you would like to see tested?
#21
Because generally when you slap a turbo on a car like a new edge mustang you are going big power/gains. Turbo on DD'ers is great !! I love turbo charged 4 bangers to drive around for a commute, they are fun and convienent but on a Mustang I would want one to put me over 500hp plus some for the cost deficit.
The supercharger is probably the cheapest way to go, but I personally prefer the benefits of a turboed car over a supercharged car (yes i realize my mustang is supercharged).
I just wish people would not associate turbos only with big power. You can have plenty of success with moderate builds as well(stock long blocks).
Oh and to the OP... sorry for mucking up your thread man... I still am very interested in seeing your turbo comparison information.
#22
Great points Teej and Moose, I would just think if a person is gonna spend all that money on a turbo kit then you mine as well build the block and shoot for more. But to each there own and Im still looking forward to seeing some test OP lol.
#23
But that's my point.. there is no reason you can't turbo a mustang and make 420hp and 530tq and not enjoy that. I don't believe you have to reach a certain power level for a turbo to become practical.
#24
and I would like to see a stock compression forged shortblock car with a 61mm turbo at 8lbs, 12lbs, and 15lbs and probably higher boost to see where it runs out of power.
Then try the next larger size with ported heads or trickflow heads, a 66 at the same boost levels and then try to max it out to see where it would benefit from a larger turbo.
Then move to a 76mm turbo with a full built motor with TFS heads and aggressive turbo cams to see where you can get your intake manifold to max out(and I'm pretty sure that this setup would max out your intake manifold).
#25
If you're going to spend all that money, wouldn't you be expecting potentially large gains? I personally would not go through all that without first building the engine up. I tend to agree with TJ here on this one, but I guess I'm assuming if you're going to F/I a car, you're aiming for 450+hp (anything over 350hp is a lot to me right now) on a very conservative tune. If I was to go the F/I route, I would go the turbo route and I would run it on low boast simply because I would kill my car and/or myself with that much power right now. I would be perfectly having a car making 450hp and running low boast. I would eventually have the car tuned to run at a higher psi though. I don't think turbos should be associated with "big power". I see nothing wrong with putting a turbo on a car like ours and not making monster numbers, I would do it simply for the torque curve. This thread has a lot of potential right now...
#26
More efficiency, better torque number. Sign me up.
#30
You buy the tranny then save for the turbo...or buy the turbo and then break the tranny and let it sit til you can get a transmission that can handle the power you wanna make. Whats your power goal? Find a used 03 cobra T56 and get a 26 spline input shaft and youre good for over 600rwhp.
