can a 2004 gt engine handle a 60 dry shot?
Old 12-10-2010, 04:32 PM
tim2002gt
tim2002gt's Avatar
If you put the nozzle in before the MAF, yes it will be "safer". There is no way of knowing how much safer it is without putting the car on a dyno and checking the a/f ratio.
As it is, you are injecting nitrous without adding any fuel. That is a huge no no. Basically what you are doing is adding a ton of oxygen without any fuel. That creates a much hotter burn and you could really mess up your motor that way.
I would suggest getting some NGK TR6 spark plugs and gap them around 0.035. Those plugs are 1 heat range colder than stock.
Also, if you have any type of performance tune loaded from a handheld you will want to return it to the stock tune before you spray it again. Performance tunes advance the ignition timing and that is exactly opposite of what you want to do when spraying nitrous into your motor.
tim2002gt is offline
Old 12-10-2010, 05:15 PM
WannaBeGearHead
Go Texas!!!
WannaBeGearHead's Avatar
Originally Posted by nascrchi
I did inject it after the MAF near the throttle body.
That would make it a wet kit setup, not dry. Put it before the MAF if it's a dry kit.
WannaBeGearHead is offline
Old 12-10-2010, 05:28 PM
MU71L4710N
MU71L4710N's Avatar
ok tim you CANNOT spray a dry kit after the maf. spraying it after the maf is how a WET kit works, spraying a dry kit (REGUARDLESS of a tune) is DANGEROUS, not safer.
Damn. First of all let me say I appreciate you telling me all this.
I have not regapped the plugs. They are at .054. I did inject it after the MAF near the throttle body. I only have shorties, o/r x-pipe, 255 walbro fp, RAM clutch, 9mm Ford racing wires oand that's it. For the night I ran 91 chevron. I was actually kidding about going with a bigger shot. I clearly understand that 60 is enough.
Another thing, if I hook the jet before the MAF will it be a bit safer? I just have the ZEX bottle with a NX selenoid. I have it hooked up exactly like the dude said above with the button being pressed with my shift hand. Haha damn
ok thats what i figured with the way you were talking. you HAVE to spray the nitrous BEFORE the maf. when you spray after the maf, your computer has no idea that nitrous was sprayed, so you get no additional fuel added. when you spray nitrous into the maf, it reads colder temperature and adds more fuel (since under normal circumstances colder air = denser = more air per volume = needs more gas to accomodate more oxygen). however, it NEEDS a dyno tune to know HOW MUCH fuel to add from the colder air.
you need to get colder plugs, ngk tr6's and i cant recall what exactly to gap them it, it may be in the nitrous stickies. someone said on another thread to do it to .042.
you need to keep premium fuel in your car, theres no "running it for hte night". because your still mixing premium with low grade and that lowers overall octane ratings.
for the love of god get a microswitch and wire it to your gas pedal atleast, and get a window switch. theres several possible and LIKELY ways you will blow your motor with a fast and the furious push button on the steering wheel...thats why REAL nitrous users dont use buttons.
MU71L4710N is offline
Old 12-10-2010, 05:49 PM
tim2002gt
tim2002gt's Avatar
Might want to re-read my post.
Btw, I have a wet kit on my car so I think I understand how it works.
To the OP, if you want to talk with somebody who can help you setup a good dry kit. PM mrtstang. Here's a link to his profile. https://mustangforums.com/forum/memb...-mrtstang.html
Old 12-10-2010, 06:32 PM
MU71L4710N
MU71L4710N's Avatar
definately read that wrong my bad :-/
Old 12-10-2010, 07:09 PM
tim2002gt
tim2002gt's Avatar
Lol, no biggie man! I had to go back and re-read it again to make sure I didn't type it wrong. Haha!
Old 12-10-2010, 07:33 PM
Blk003GT
Blk003GT's Avatar
Originally Posted by 1SLO85
SURVIVAL OF THE FITTEST. SPRAY the Hell out of it!!!
Lmao! When it doubt spray it! Haha
Blk003GT is offline
Old 12-10-2010, 07:40 PM
tbirdscwd
tbirdscwd's Avatar
Can you explain to me why having a dry kit is just plain dangerous? The engine doesn't care where the extra fuel comes from.........as long as the extra fuel is there
tbirdscwd is offline
Old 12-10-2010, 08:06 PM
WannaBeGearHead
Go Texas!!!
+1000
Old 12-10-2010, 08:25 PM
boduke0220
boduke0220's Avatar
there was something on another board one time like..
Getting Beat by Hondas? Spray it
Cant hook? Spray it
Rear end going out? Spray it
Spun rod bearing? Spray it
Cant get laid? Spray it
boduke0220 is offline
Quick Reply: can a 2004 gt engine handle a 60 dry shot?
