UPR control arms
Old 04-24-2012, 10:03 PM
HamMach1
HamMach1's Avatar
I have seen TeamZ mentioned quite a bit. Never hears of baseline
HamMach1 is offline
Old 04-24-2012, 10:14 PM
Jay-rod427
Jay-rod427's Avatar
I have UPR uppers and lowers with solid heim joints on both ends of both. They do make A LOT of noise on the street and even the ride quality sacrifices a little. for the price they can't be beat! They definately improved 60' times on the track!
Jay-rod427 is offline
Old 04-24-2012, 10:18 PM
russellthelovemuscle
russellthelovemuscle's Avatar
i have uprs tubular k member and a arms on my 2000 gt. i baught the set that came with coil overs and i love it. dropped a ton of weight in the front end, looks tight, but the coil overs are a waste. great kit, coil overs garbage
russellthelovemuscle is offline
Old 04-25-2012, 07:16 AM
dwtjr3
dwtjr3's Avatar
Originally Posted by jeh4269
Keith and I installed a set of lowers on my car.They have a poly bushing at one end and a heim joint at the other end.For the first couple weeks they were doing a lot of creaking.Like they were breaking in or settling.Now they are as quiet as my stock set was.I would recommend them.
What set did you go with?
dwtjr3 is offline
Old 04-25-2012, 08:05 AM
lizzyfan
Underboss
lizzyfan's Avatar
Originally Posted by oxfordgt
I have never used and never will use Maximum Motorsports parts. Too heavy, bad designs and way overpriced. Basicly MM is for turning not going fast.
Helped me hit the 11's
lizzyfan is offline
Old 04-25-2012, 09:30 AM
Repzard
Repzard's Avatar
I sure like my UPR KC Clutch (Valero)
Price was great too.
Repzard is offline
Old 04-25-2012, 10:52 AM
WannaBeGearHead
Go Texas!!!
WannaBeGearHead's Avatar
Still doesn't mean OX is wrong about them being too heavy, overpriced and mainly designed for hardcore turns.
I had MM LCAs and Baseline's LCAs and they are like night and day different in design and weight.
WannaBeGearHead is offline
Old 04-25-2012, 11:22 AM
oxfordgt
oxfordgt's Avatar
Not trying to be an *** at all but the times in your sig are not helping your cause in trying to prove MM makes good parts. With your power and MPH you should be running sub 11. I was cutting 1.6 60' with cut stock springs, stock uppers and steeda lowers on a DR. With your power and good suspension parts you can cut 1.3 60' and run 10.80s easy.
oxfordgt is offline
Old 04-25-2012, 03:27 PM
HamMach1
HamMach1's Avatar
Are Steedas pretty good?
HamMach1 is offline
Old 04-25-2012, 04:49 PM
lizzyfan
Underboss
lizzyfan's Avatar
I suck
lizzyfan is offline
Quick Reply: UPR control arms
