how long does it take h&r ss spring to settle?
Old 05-04-2012, 03:25 PM
Gt04
Gt04's Avatar
Originally Posted by dwtjr3
How much of a difference did you notice right away tho?
About the same as you for the first day or so
Gt04 is offline
Old 05-04-2012, 04:05 PM
kast1376
kast1376's Avatar
Mine were fully dropped almost 2" literally right after the install. (I didn't run the ISOs, fwiw)
kast1376 is offline
Old 05-07-2012, 09:03 PM
hpwrestler220
hpwrestler220's Avatar
Did you get poly isos or did you reinstall the old ones?
My fronts make no noise with or without isos. The rear needs the isos, however.
You should be seeing more than 3/8" of a drop bc I highly doubt they'll settle 1.5"... Poly isos will subtract half an inch off ur initial drop if u bought those...
hpwrestler220 is offline
Old 05-07-2012, 10:01 PM
jtb727
jtb727's Avatar
did you buy the race springs? or the SS? Mine was slammed immediately...
jtb727 is offline
Old 05-08-2012, 06:04 AM
dwtjr3
dwtjr3's Avatar
I have SS springs, and i did buy poly isos. So will the isos eventually settle in?
dwtjr3 is offline
Old 05-08-2012, 01:11 PM
hpwrestler220
The poly Isos's are made of a much thicker/stronger compound i have heard. They don't settle as much as the stock rubber isos. Cars with poly isos sit half an inch higher than cars with stock isos. I really don't know why anybody would spend the money on new poly isos (not to knock you)
Why get H&R SS springs and put poly isos in? Might as well buy a spring with a 1.25" drop and leave the stock isos in...
Go back in the front and remove those isos. Put the stock isos in the rear. Be done with it. You won't have any squeaking
Old 05-08-2012, 09:49 PM
dwtjr3
dwtjr3's Avatar
Yeah man if I would of known poly isos didn't settle as much I wouldn't of gotten them and wasted the money. I really wish I would of used the stock ones and saved the money
dwtjr3 is offline
Old 05-08-2012, 10:27 PM
PurpleIcedGT
PurpleIcedGT's Avatar
^I think you just said the same thing twice
PurpleIcedGT is offline
fcarpio
Suspension
11-16-2018 10:35 AM
robcy
Suspension
10-27-2015 11:14 PM
Gene K
10-21-2015 11:37 PM
09-08-2015 11:50 AM
Quick Reply: how long does it take h&r ss spring to settle?
