Firm up a convertible?
Well, my search continues for my next Mustang. I have narrowed it down, it will be a GT convertible in the 1998 to 2004 model year range.....don't get me wrong, if the correct Cobra convt came along at a killer price, all stock OEM equipped I would be open to a Cobra. But, finding a straight stock non abused Cobra is not as easy as one would think.
I am more of a looking for a little driving pleasure on a nice day person, not an I need the power to the ground required individual. I've been doing a little soul searching as to what I am really looking for, and have deceided that I don't want to go for someone elses project and wonder what has and has not been done properly. Plus, if I start with a clean slate, it will be my choice of direction if it enters a performance build later.
Having had a 1999 convt best I can recall it was a little more than flexish at time. While I am looking to keep the stance as close to factory, I would like to firm up the flex issues. My thought is that a pair of full length frame connectors (welded), rear shock tower, and front strut brace should help address the matter.
Am I on the right track?
FLSFCs:
http://www.uprproducts.com/mustang-f...onnectors.html
strut tower brace:
http://www.uprproducts.com/bbk-musta...-black-94.html
Then you can start upgrading the suspension. The suspension mods won't tighten up the chassis, but they'll tighten up the suspension.
you get when you make turns and overall firm up the ride quality.
Get full length subframe connectors if you don't mind adding
35 pounds or so to you mustang because they do weight some
but they will benefit your mustang though with good ride quality.
Suspension would be the first place I would start on a convertiable
mustang.I would also consider some nice springs and struts and shocks
they will help too.
flsfc's should be one of the first mods anyone with a vert does, the stock bolt in subframes are crap and you will notice a night and day difference once you install them. They are well worth the money to put on a coupe or vert but verts definitely need them. And ignore anything the troll blade****er says.
Looking to install the sub-frame connectors on my 2002 GT vert. I have a question about the factory bolt-on ones on the car now. Would they be in the way of welding the new sub-frames? If not, would you recommend removing them anyway.
You'll immediately notice the difference in quality and rigity (thicker steel) between "real" aftermarket sfc's and the stock ones once you get them and unbox them.
To get off my soap box and answer your question though, the stock ones will be unbolted and discarded when you install aftermarket sfc's.
