Help, TR-3650 shifting issue
Sooooo, lately my tranny has been really hard to shift in all gears including reverse. It's SUPER notchy and doesn't want to get into gear sometimes unless im feathering it in... I'm wondering if it needs the oil changed at this point but it's baddddd. I'm currently running. royal purple synchromax in it. It has not been changed since like..um..2006?
Anyways , has anyone wit the same transmission had this issue corrected with A similar problem? Is it more than n oil change issue ya think?.what oil should I go with? I heard Mobil 1 ATF could be better than RP?
Have you tried adjusting the cable? Like stated above either the cable is stretching or the clutch itself is on its way south...Push the pedal to the floor twice, let up, and then pull the pedal up towards you (driver seat) and if its not in adjustment anymore, you will hear some clicks.. If its good, it wont move or click at all. If that doesnt work, I'd look into the condition of the clutch..
Well that kinda rules out what I posted lol. Definitely try to adjust that cable. 3650s are known for synchro issues but problems with every gear all at once is a clutch issue
