stiff shifter
Old 12-25-2013, 03:22 PM
De Nub 03gt
De Nub 03gt's Avatar
Default stiff shifter
Received a short throw shifter for Christmas. . Installed it today, it's crazy tight, I have to really put some force into it pushing to the right to get it into 5th from 4th and from neutral to reverse and I'm a bigger, stocky guy, is it normal to be this tight? Also it's a little notchy, but nothing too serious
De Nub 03gt is offline
Old 12-25-2013, 03:24 PM
De Nub 03gt
Oh, and there is no grinding or anything like that, just really hard to shift to the far right gears.. If there isn't an issue I guess I'll just deal with the stiffness because the throws are noticeably shorter
Old 12-26-2013, 07:10 AM
PurpleIcedGT
PurpleIcedGT's Avatar
Thats the purpose brother!
PurpleIcedGT is offline
Old 12-26-2013, 07:15 AM
De Nub 03gt
So 5th and reverse are supposed to be really hard to push the shifter over far enough to get in to?
Old 12-26-2013, 12:11 PM
flmcgough
flmcgough's Avatar
What brand is it? My Hurst started off VERY stiff and notchy, but it's loosened up a bit (especially the stiffness; less so the notchiness) over the past couple years.
flmcgough is offline
Old 12-26-2013, 06:06 PM
De Nub 03gt
I couldn't tell you honestly, I don't feel appropriate asking, it being a gift and all, but I don't mind it as long as it isn't hurting anything.. I've been leaving it in reverse when parking it ( the hardest gear to get in to) to see if it helps loosen it up
Old 12-26-2013, 06:07 PM
De Nub 03gt
Also, I know it won't be a crappy one, considering it's my dad and he always makes sure I get reliable brands, etc..
Old 01-14-2014, 10:47 AM
Fryguy22
Fryguy22's Avatar
What color is the shift handle? It didnt have a brand imprint on the base?
I believe it will loosen up quite a bit. It probably doesn't help that its been incredibly cold out.
Fryguy22 is offline
Old 01-17-2014, 10:58 AM
De Nub 03gt
It has loosened up a lot since I started this thread, thanks everyone
Old 01-17-2014, 10:57 PM
CobraFrenzy
CobraFrenzy's Avatar
should tell you what kind it is on the base of the shifter
CobraFrenzy is offline
firehorse02
11-16-2015 11:28 AM
Explosive
10-02-2015 07:45 AM
guitarman376
09-30-2015 05:54 PM
junior04
09-28-2015 10:53 AM
ccdguy
09-19-2015 05:20 PM
Quick Reply: stiff shifter
