Did I use the wrong fluid in my power steering pump??
Old 12-31-2013, 01:22 PM
tracyballard
tracyballard's Avatar
Default Did I use the wrong fluid in my power steering pump??
Well, I got my power steering pump replaced and it works great, but now I'm worried because it looks like I used the wrong fluid. I was originally advised in another post that Dexron IV was correct, but when I got to the store all I saw was Dexron VI, so I just assumed VI was what the guy was talking about. But after looking at the manual, which recommends Mercon (of which Mercon V is current), and doing some checking, it seems that Mercon V is not compatible with Dexron VI, at least as far as transmissions go. So, do I need to drain all this out and use Mercon V???
tracyballard is offline
Old 12-31-2013, 01:30 PM
Z28KLR
Z28KLR's Avatar
My best guess is it's probably fine. It just uses the atf as a hydraulic fluid, so the difference between the friction modifiers found in Mercon vs. Mercon V or whatever shouldn't matter since it's not a transmission which would be sensitive to those differences.
All that said though, if it were me, just out of paranoid/ocd tendencies I would probably replace it with Mercon as specified.
Z28KLR is offline
Old 12-31-2013, 01:35 PM
Derf00
Gentleman's Relish
Derf00's Avatar
You are fine. The label or Data sheet on the mfg website of the brand you bought will specify "supersedes previous Dexron/Mercon specifications" or something like that.
Like this one...
http://images.peakauto.com/PEAK%20FS...ercon%20LV.pdf
Derf00 is offline
Old 12-31-2013, 01:51 PM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
dex6 i believe is GM spec stuff.... should be ok either way
WhiteFoxGT is offline
yourmom6990
3.7L V6 Technical Discussions
10-14-2015 10:08 PM
importsmasher
10-09-2015 04:42 PM
5.0 kevo
09-03-2015 06:24 PM
whatsup62
09-03-2015 01:38 PM
Quick Reply: Did I use the wrong fluid in my power steering pump??
