2005/2006 Stock Mustang GT Tune
Old 08-10-2010, 04:37 PM
hammeron
hammeron's Avatar
Default 2005/2006 Stock Mustang GT Tune
Here we'll be taking a peek inside the Ford Mustang GT calibration.
As parts of the tune are broken down for presentation, I will add them in the 5 reserved slots below. Topics of interest are WOT ignition timing, WOT cam timing, WOT air/fuel ratios, ignition timing retard/advance (based on knock sensor feedback as well as air,coolant & oil temperatures. And finally, we'll tie everything together to see how at WOT the engine produces the power that it does.
The stock calibration is for 87 octane.
hammeron is offline
Old 08-10-2010, 04:38 PM
hammeron
hammeron's Avatar
WOT Ignition Timing
Base timing for the 4.6L 3v engine, is 10* Before Top Dead Center.
Here is the WOT ignition timing curve. Maximum timing advance (17.5*), happens at 4750 rpms.
Explanation of timing
Timing refers to when the spark plug fires in relation to the piston's position. Base timing of 10* means that the spark plug fires when the piston is 10* Before Top Dead Center.
Advanced means the spark is happening earlier than base timing.
Retarded means spark is happening later than base timing.
What is the graph telling us?
WOT below 1000 rpms results in spark happening at exactly Top Dead Center. Only after rpms reach 1000 will spark begin to occur before Top Dead Center. The zero line of the chart (in the Y axis) is equal to base timing, which is equal to 10* BTDC.
So there are a couple of ways to define your max timing. One way is to reference to Top Dead Center, in which case total timing would be 27.5*. The other way is to reference to base timing, in which case our timing advance would be 17.5*.
hammeron is offline
Old 08-10-2010, 04:39 PM
hammeron
hammeron's Avatar
WOT Cam timing
Here is the WOT cam timing curve. If you are under 3000 rpms when you go WOT, the cams will start out
at 0 degrees (this means full advance, which is the default position for the cams). At 3000 rpms the PCM will begin to retard the cams, reaching a maximum of 9* retard by 5750 rpms.
hammeron is offline
hammeron
hammeron's Avatar
reserved 3
hammeron is offline
Old 08-10-2010, 04:40 PM
hammeron
hammeron's Avatar
reserved 4
hammeron is offline
hammeron
hammeron's Avatar
reserved 5
hammeron is offline
Old 08-10-2010, 06:49 PM
Nuke
Nuke's Avatar
Cool. Looking forward to your dissection... er... data.
Nuke is offline
Old 08-10-2010, 06:51 PM
BruceH
BruceH's Avatar
Having some fun with your Racer software?
BruceH is offline
Old 08-10-2010, 08:04 PM
hammeron
hammeron's Avatar
welcome gentlemen, sharpen your pencils and dust off your PeeChees.
hammeron is offline
Jacob4589
08-17-2015 09:34 PM
01blackgtconv
08-14-2015 04:50 PM
'stangdude
08-12-2015 01:27 PM
daytooday
08-11-2015 09:22 AM
BlackShelbyGt500
08-10-2015 11:50 AM
Quick Reply: 2005/2006 Stock Mustang GT Tune
