What cam do you think I should go with?
Old 01-14-2012, 09:52 AM
Simon1
Simon1's Avatar
I would save your money and look at getting a whipple, Kenne Bell or big TVS blower. You have probably hit an efficency limit of the magnacharger and thus your gains will be insignificant, even with more boost.
See if you can find some more info on your blower and what it's efficency range is.
Simon1 is offline
Old 01-14-2012, 10:26 AM
sactown
sactown's Avatar
Originally Posted by streetyme
Kurt Borton from MCP is the one tuning my car.. His own car is the Worlds Fastest 4.6 3.v.. His Fairmont runs 7.80's at 192.. That is a Boss block and a F2 with a powerglide. I think one of the problems is the sc is Not the most effiecent... I was looking back at my sheet and it (AF) fattens up to 11.7 across the range. .. Your car is defintely running well... You have a good setup. I want to forge the motor and eventually throw another sc at ; maybe not a F2 though.
If your at 11.7 your fine. There are a couple of things I would spend the money on before buying cams. Wait tell you replace the motor to do cams, the stock cams are actually very good.
1. k-member, a-arms, and radiator support
2. ice box for the trunk to bring inlet temps down
3. race gas tune
4. save the money for another SC
Just curious, what are your 60ft times?
sactown is offline
Old 01-14-2012, 11:54 AM
streetyme
streetyme's Avatar
Thanks guys for the advice.. Next supercharger I'll defintely make sure I have some headroom and that I have room to grow.. I am being told that when I upgrade the motor to possibly see about throwing a TH400 in there instead of the 5r55, but I do like my overdrive. The Magnacharger is based on the 112 Eaton roots style blower. Honestly sactown it's never been down the track.. I live right outside St Louis Mo and the local track Gateway International in Madison IL closed down last year.. Kurts thinks its around a 11.7-11.8 right now at about 117 , but that just a best guess..
streetyme is offline
Old 01-17-2012, 08:11 PM
Simon1
Simon1's Avatar
You can put a gear vendor on any transmission. They are pricey though.
Simon1 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
patchshaffer
Tuner Central
10-05-2015 02:24 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
junior04
09-28-2015 10:53 AM
Ryan Fitzpatrick
09-14-2015 02:21 AM
Quick Reply: What cam do you think I should go with?
