is 15w 50 weight oil too heavy?
Old 12-10-2012, 06:48 PM
SpartaPerformance
SpartaPerformance's Avatar
Originally Posted by moosestang
Ideal for what? Cruising around town maybe.
Noooooo, it's the proper viscosity oil for the motor. No reason to use anything else.
SpartaPerformance is offline
Old 12-11-2012, 04:20 PM
debit_free_2010
debit_free_2010's Avatar
Originally Posted by DTMR
How is 0w-30 too thin and 15w-50 too heavy?? What would u use then? (the first number should always be lower because you want the oil to be thin at start up apparently from what I read on that bob the oil guy site)
The 1st number is how well the oil will flow in colder environments, you only need a 0weight oil if you live where it stays under Zero for extended periods (ie Canada).
5w-30 or 10w-30 will work fine as long as you don't see really low temps. The reason Ford uses the 5w-20 is for the minor fuel mileage gains it supposedly gives.
Funny story, years ago I was stationed in Florida where I ran 20-50 oil in my old Trans Am. I moved to Illinois in October and it turned COLD with 20' temps and went out to crank my car and the freakin engine was locked up. I had to change the oil to get it to crank.
debit_free_2010 is offline
Old 12-11-2012, 06:46 PM
DTMR
DTMR's Avatar
haha wow thats crazy
DTMR is offline
baddog671
07-26-2016 01:20 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
wraith777
09-28-2015 10:49 AM
jar_are_red
09-24-2015 07:03 AM
2015Ecoboost
09-17-2015 01:48 PM
Quick Reply: is 15w 50 weight oil too heavy?
