Underdrive pulley installation
Take the throttle body money and get some delete plugs. They install under the intake manifold and are good for a few extra hp. Work good with the pulleys. I did it to my 06. (They are delete plates in 06) more gain than the TB for sure!
wetwille3,
Sounds like you have everything figured out already. These guys have good advice with installing the UDP's!
I did want to mention that we've had a lot of good feedback about the twin blade SR Performance TB. You'll see increased throttle response and more low to mid ranged power. Also, I've only seen a 2 or 3 threads where a customer had drive-ability issues with this particular TB. However, all of their issues were fixed after an idle-relearn sequence, which is mandatory after install.
The best part about the SR TB is its reduced pricing compared to other aftermarket brands. Which is why I thought I'd see if you would be interested!
Shane
Shane
Sorry, I'm still not convinced that the TB adds any power compared to the stock TB; V6 OR V8; unless you're really moving a LOT of air being SC'd, bored, etc...
