COOLAN LEAK
Old 02-24-2014, 09:15 PM
g150rdt
g150rdt's Avatar
Unhappy COOLAN LEAK
I got home and notice that coolant was coming out from under the cap on the degas tank (aluminum). The temperature was around 205*. This has never happened before, is the thermostat shot or air in the system???. Thank for your help.
g150rdt is offline
Old 02-24-2014, 10:49 PM
tx_zstang
tx_zstang's Avatar
Sounds like the cap properly vented under 15-16 psi of pressure (good).
If the temp was that high, yeah, something is wrong to make it run hot.
tx_zstang is offline
Old 02-25-2014, 08:31 AM
g150rdt
g150rdt's Avatar
Thanks, I will check the thermostat, see if is working or get a 160* one.
g150rdt is offline
Old 03-03-2014, 12:28 PM
02WhiteGTVert
02WhiteGTVert's Avatar
Did you recently do anything to the car (like install an aluminum degas bottle)?
If so there could be air in the system. Second could be a failing cap if the car's beginning to overheat.
160* is too cold for a thermostat, especially if you live in a warmer climate. By dropping the temperature 20*, your thermostat will be open quicker/longer, thus leaving the coolant less time in the radiator to cool, which may lead to overheating problems because the cooling system cannot keep up.
If the factory thermostat is doing its job, you have a problem elsewhere.
02WhiteGTVert is offline
4cylinderplus2
10-09-2020 07:45 PM
bradleyb
11-27-2015 07:50 PM
jerrytubes
10-23-2015 12:11 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
wraith777
09-28-2015 10:49 AM
Quick Reply: COOLAN LEAK
