Looking for 05-09 Nitrous Plate (to fit Ford Racing Throttle Body)
Old 03-21-2014, 02:14 PM
Mellowdien
Mellowdien's Avatar
Default Looking for 05-09 Nitrous Plate (to fit Ford Racing Throttle Body)
Hey Guys,
I've been looking for a nitrous plate for my somewhat "custom" nitrous set-up. I use mostly ZEX components. The nitrous plate has to be able to fit with my Ford Racing Throttle Body and stock intake manifold (preferably also a Ford Racing Intake Manifold as i might be upgrading in the near future).
I've been spraying a 100shot. Want to go up to 150 but prefer to do so with a plate.
I've spoken with a few manufacturers but none can be sure whether or not it will fit the with aftermarket throttle body or in the future with an aftermarket intake manifold.
Any suggestions?
Mellowdien is offline
Old 03-27-2014, 08:42 AM
Evo2s197
Evo2s197's Avatar
I don't see why the below setup wouldn't work with the FRPP IM, if anything you might have to rebend the hard lines on each side or get new one as the FRPP is a tad bit wider and taller. As for any after market TB not sure about that because the plate systems available are port matched to the factory size.
http://www.nitrousoutlet.com/efi-wet...allery-image-4
Evo2s197 is offline
Old 07-22-2014, 09:52 PM
kwhodson
kwhodson's Avatar
Originally Posted by Mellowdien
Hey Guys,
Any suggestions?
Did you ever find this? I am running the FRPP 62mm throttle body and the FRPP intake...I want to use the NX Plate system
kwhodson is offline
Old 07-29-2014, 10:17 AM
Mellowdien
Mellowdien's Avatar
Hodson, no i've stuck with the current "hole in the intake" system for now. It works fine with the 100shot. Most people just advised me to use a plate when going above the 100shot as it might have some issues due to the throttle bodies being dual and not mono.
I have purchased a nitrous outlet plate. I'll start playing with it as soon as it gets here. But if you beat me to it, please share!
djbigskrilla
09-20-2022 01:04 AM
01blackgtconv
08-14-2015 04:50 PM
stanngg
08-12-2015 03:43 PM
01blackgtconv
08-10-2015 01:25 PM
Redneck1465
08-08-2015 10:39 PM
Quick Reply: Looking for 05-09 Nitrous Plate (to fit Ford Racing Throttle Body)
