positive side battery terminal is hot
Old 05-06-2014, 08:41 PM
tommya
tommya's Avatar
Default positive side battery terminal is hot
I was putting my 2006 GT away in the fall and noticed that when I disconnected the positive side battery cable was warm, almost hot. Just got it out of storage and reconnected the cable and started it and felt the cable was starting to warm. Car is running fine and the amp gauge is within. Any ideas?
tommya is offline
Old 05-06-2014, 09:42 PM
Chromeshadow
Chromeshadow's Avatar
That usually means the connector or post is not clean. Did you clean them both with a battery post brush ?
Chromeshadow is offline
Old 05-07-2014, 06:36 PM
tommya
tommya's Avatar
Thanks for the advice Chromeshadow. In the process of removing the positive side of the cable, I found that the secondary cable was not quite tight enough. About a half a turn solved the problem. Thanks again.
tommya is offline
Old 05-07-2014, 09:16 PM
Goldenpony
Goldenpony's Avatar
Heat=high resistance=dirty/loose connection.
Goldenpony is offline
TfcCDR
09-14-2015 12:08 PM
MusicCity615
09-12-2015 07:05 AM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
Art161
09-09-2015 10:33 AM
Mobiusone stang
09-07-2015 08:46 PM
Quick Reply: positive side battery terminal is hot
