4 Cylinder NA and Turbo This section is for questions pertaining to stock or modified 4 cylinders, including the performance 2.3L applications
fuel pump questions
Old 08-27-2008, 09:53 AM
alboy91lx
alboy91lx's Avatar
Default fuel pump questions
is there a differance with the 5.0 and 2.3 fuel pumps? will this fit my 91 4 banger?
http://store.summitracing.com/partde...5&autoview=sku
alboy91lx is offline
Old 08-27-2008, 11:25 AM
icelandismine
icelandismine's Avatar
I don't know if there was a difference in volume, but they were shaped the same. Yes, that will fit. I bought almost the exact same pump for mine.
icelandismine is offline
Old 08-27-2008, 01:55 PM
ExtrmZ
ExtrmZ's Avatar
there should be no problem getting that to fit into your car..
ExtrmZ is offline
Old 08-27-2008, 04:52 PM
alboy91lx
alboy91lx's Avatar
alright its in... i bought a bbk 255 lph... i got it for 140.00 a summit today... it was so ****ing easy...
Old 08-27-2008, 07:05 PM
ExtrmZ
ExtrmZ's Avatar
what did you have to do? i have never done one.. just wondering
ExtrmZ is offline
Old 08-27-2008, 09:27 PM
icelandismine
You drop the tank, take the old pump out, put the new in. It's very easy.
Notes: Release fuel pressure before taking fuel lines off, and it's a good idea to have spare gas tank straps.
alboy91lx
alboy91lx's Avatar
disconnet fuel lines... filler neck... then drop the tank far enough so you can take the wires off the pump and sending unit... then drop the rest of the way... that the hold down nut on the pump and pull out... and reverse to instail... but while its out you should replace the filler neck o-ring thing... i wishi would of... gas is goung eerywhere...
Tivo304
08-28-2023 12:19 PM
raleigh05GTO
09-04-2015 07:09 AM
5.0 kevo
09-03-2015 06:24 PM
SYNY5TER
09-02-2015 01:35 AM
Quick Reply: fuel pump questions
