4 Cylinder NA and Turbo This section is for questions pertaining to stock or modified 4 cylinders, including the performance 2.3L applications
93 2.3L check engine light stays on for a few minutes of driving
Old 10-28-2011, 07:01 PM
TC10284
TC10284's Avatar
Default 93 2.3L check engine light stays on for a few minutes of driving
Last year around this time I replaced the air bag module in the center console on my 1993 Mustang LX 2.3L. At that time, the symptoms were:
Airbag light on dash flashing twice
Occasionally the module itself would beep at me
The check engine light would come on a few minutes after starting to drive the car, then would stay on for a few minutes of driving, then finally cut off. Car ran fine.
After replacing the air bag module, the problems went away. I drive my 93 LX every few weeks. I think the most I've let it sit was a month.
The other day, the air bag light flashed at me again. Shortly after driving, the check engine light came on but the car was running just fine.
I've started the car the past few days, let it sit and run for about a minute, looking for the airbag light to flash at me again. It did not. Nor did the Check engine light come on.
Today, I drove the car uptown and the Check Engine light came on solid on the way up for about 5-10 minutes, then went off.
On the way home, the Check Engine light came on with about 10 minutes of the 20 minute drive left to my house. It stayed on for about 3-5 minutes and went off. The Airbag Sensor light did not come on.
In each case, the car runs fine.
I don't get what's going on. Can the airbag module throw the Check Engine light too? Do I need to purchase another airbag module for my model?
TC10284 is offline
Old 10-28-2011, 10:20 PM
Mr93MoStang
Mr93MoStang's Avatar
I don't think so. My '93 has no module at the moment. I've run my scanner on it and the only codes i get are for high injector pulse width. Not even related to the air bag. You might have another problem. Also if it is a junk yard module it might be bad. The car is in the junk yard for a reason. And if the air bag module would throw a code then it wouldn't have its own light. So I think that you have 2 problems that just happen to be happening at once.
Mr93MoStang is offline
Old 10-29-2011, 11:01 AM
TC10284
TC10284's Avatar
The replacement airbag module was a junkyard part but was noted as not wrecked/airbag did not deploy.
It just seems odd to me that the Check Engine light would suddenly start coming on solid right after the airbag sensor light flashed.
Yesterday I drove it again and noted that the notification tone (like when you leave your lights on with engine off and you open the door, or leave your keys in the ignition with engine off and open the door) will beep once, then not again. Each time it happened I did not have the keys in the ignition or lights on.
TC10284 is offline
Old 10-29-2011, 11:03 AM
TC10284
TC10284's Avatar
I need to clarify what I said:
Yesterday I drove it again and noted that the notification tone (like when you leave your lights on with engine off and you open the door, or leave your keys in the ignition with engine off and open the door) would beep once when I turned off the car and opened the door, then not beep again. Each time it happened I did not have the keys in the ignition or lights on.
TC10284 is offline
Old 10-30-2011, 05:33 PM
Mr93MoStang
Check all ur fuses thats strange. never heard of that being a sign of the air bag module going bad
djbigskrilla
09-20-2022 01:04 AM
microgt
08-20-2015 07:12 AM
mweiland
08-13-2015 05:11 PM
drumhedd2005
08-13-2015 09:59 AM
Mustangdanny
08-10-2015 09:34 PM
Quick Reply: 93 2.3L check engine light stays on for a few minutes of driving
