4 Cylinder NA and Turbo This section is for questions pertaining to stock or modified 4 cylinders, including the performance 2.3L applications
4 cyclinder with v6 t5 transmission
Old 03-23-2014, 02:16 PM
Papa Kenji
Papa Kenji's Avatar
Default 4 cyclinder with v6 t5 transmission
I have an 89 fox body 4 cyclinder with the light duty t5 transmission. I have a chance to buy a t5 transmission from an 96 3.8 v6. Does any one know if it will bolt rate in or do I need to change anything. If not should I go with a t5 out of a 8 cyclinder.
Papa Kenji is offline
Old 03-24-2014, 01:15 PM
PNYXPRESS
PNYXPRESS's Avatar
Make sure the t5 from the sixxer has the same pilot bearing size as the 4 cyl. I know the 99-04 v6 t5 will NOT fit. likewise with the v8 t5 as the pilot bearing is bigger.
PNYXPRESS is offline
Old 03-28-2014, 09:56 AM
Papa Kenji
Papa Kenji's Avatar
thanks. ive done some more research. all over the web. this is what i found. http://i8.photobucket.com/albums/a38...c/t5_specs.jpg
Old 04-27-2014, 12:28 PM
Papa Kenji
Papa Kenji's Avatar
Just an update finally found a a 2.3 transmission next step is to replace the rear end I messed up. And to replace the drive shaft that I spun the balancer off of.
63Falcon
07-15-2010 11:45 AM
IronOutlaw
08-06-2009 12:59 PM
GBecker1
11-30-2008 09:25 PM
jEEd
32
11-11-2007 09:42 PM
crazyknight
04-24-2006 01:15 AM
Quick Reply: 4 cyclinder with v6 t5 transmission
