Are These Gears Junk?
Old 05-16-2006, 09:24 PM
  #21
ckyguy68
ckyguy68's Avatar
Default RE: Are These Gears Junk?
thanks! very helpful.
ORIGINAL: mcfomco
I got lucky on mine the shims that where already in the rear end put me almost perfect on the pinion depth and basklash. I am only like 1-2 thousandths away from the center of tolerance measurements. From what I have discovered most not all but most 3.73 gearsets usually use the same shims as 2.73.
http://www.angelfire.com/theforce/5o...5ohtech001.htm this site helped out alot on mine good luck.
ckyguy68 is offline
Old 05-16-2006, 09:32 PM
  #22
Joel5.0
Joel5.0's Avatar
Are Motive Gears junk?.........want to guess what the "M" at the end means in FRPP part number M-4209-G355M means?.........
Joel5.0 is offline
Old 05-16-2006, 09:40 PM
  #23
Goosepoop302
Goosepoop302's Avatar
ok so to whoever installed your own gears is that the first time you have ever done it?? also did you need any special tools the average mech wouldant have?
Goosepoop302 is offline
Old 05-16-2006, 09:43 PM
  #24
92hatchLX
92hatchLX's Avatar
I talked to Brent a while ago (brenspeed.com owner) and he said that the gears are great, and they are infact motive. I would trust brenspeed.com with any performance part, I order almost everything through them.
92hatchLX is offline
Old 05-16-2006, 09:51 PM
  #25
OneFine89Mustang
OneFine89Mustang's Avatar
them gears are fine i bought gears from brenspeed before no problems
OneFine89Mustang is offline
Old 05-16-2006, 10:05 PM
  #26
Joel5.0
Joel5.0's Avatar
ORIGINAL: Goosepoop302
Pinion Depth Setting Tool
or, alternate Pinion Depth Gauge for Ford 8.8
I don't know how accurate the gauge alternative is, I'll let you know when I finally install my 3.90 Motive gears since I have both tools.....bought the cheap gauge to verify if it's a reliable/accurate way of installing/setting them quicker.
Joel5.0 is offline
Old 05-16-2006, 10:20 PM
  #27
Goosepoop302
thanks please let me know how it works out also where u get the more expensive one?
Thunderball
15
11-22-2015 11:49 PM
Bokeo
10-10-2015 08:28 PM
KingRando
10-02-2015 08:06 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
junior04
09-28-2015 10:53 AM
Quick Reply: Are These Gears Junk?
