Newb to fox body question.
Old 05-24-2006, 02:34 AM
Tik_Tok
Tik_Tok's Avatar
Default Newb to fox body question.
Hey guys, I'm looking at an `87 2.3L vert.... i'm sure you've heard this question more than once [8D] but......
How hard would it be to swap the engine to a n/a 5.0L? I've heard the bodies are the same structurally, and that the front brakes suck on a 4 cylinder. Asides from that I'm assuming I'd need new front springs to compensate for weight.
Will the automatic transmission hold together? will it mate properly? will the rear end hold together?
With the actual install of a 5.0, is it difficult?
Any help would be appreciated.
Tik_Tok is offline
Old 05-24-2006, 02:37 AM
rmodel65
Yukon Cornelius
rmodel65's Avatar
Default RE: Newb to fox body question.
just get a wrecked 5.0 and start swappin need plenty of space!!!! the auto for the four will have to go and the brakes need to be v8 spec at least. but they suck also! u can leave the four cylinder spring in place for a drop in the front!
rmodel65 is offline
Old 05-24-2006, 04:21 AM
bottlebaby
bottlebaby's Avatar
http://www.jason.fletcher.net/tech/v8/v8.htm
here is a good link to read and maybee answer some of your questions.......
bottlebaby is offline
Old 05-24-2006, 12:46 PM
Tik_Tok
Tik_Tok's Avatar
ORIGINAL: bottlebaby
Great link, thanks!
Tik_Tok is offline
Old 05-24-2006, 12:57 PM
88BlueGT
88BlueGT's Avatar
The stock rearend will hold up on a stock 5.0 but once you start modding it and it takes some abuse it will fail.
88BlueGT is offline
UrS4
10-03-2015 06:23 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
RCS02v6
09-29-2015 01:46 PM
GLOCKer
09-28-2015 07:36 AM
2poor4u2
09-26-2015 11:08 AM
Quick Reply: Newb to fox body question.
