Hellion Turbo Kit, AFR 185's, BBK SSI
Old 06-16-2006, 12:22 PM
  #41
Dirty Sanchez
Dirty Sanchez's Avatar
Default RE: Hellion Turbo Kit, AFR 185's, BBK SSI
I have the Hellion kit on my car, and made 436whp / 508wtq @ 10psi with ported stock E7's, ported Cobra intake and ****ty B303 cam. I then found out that my valve springs only had 50lbs. of seat pressure, and replaced those. I'm guessing after the valve springs were replaced, the car is probably making closer to 470whp @ 10psi. I'm guessing if you go with a nice set of heads and a nice intake (not the SSI, I'd recommend a Performer 2, Track Heat or Systemax) you should have no problems getting to 500whp. Have some money set aside, because your stock tranny is going to lay down eventually.
Dirty Sanchez is offline
jwog666
12-27-2021 08:09 PM
Stone629
The Racers Bench
66
06-02-2016 09:52 PM
Lethaldosage423
10-19-2015 12:12 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
Quick Reply: Hellion Turbo Kit, AFR 185's, BBK SSI
