Tire Pressure
RE: Tire Pressure
ORIGINAL: Shifty5.0
Alright, so i blew a right front the other day and i was wondering what kind of psi other ppl are running. is it good to run low or high? or what... i would like some info
RE: Tire Pressure
Don't set them at the Sidewall pressure...that is the Maximum. Like mentioned above, the tire pressure will increase 3-5 lbs when driven (hot) and that could spell trouble. There should be a sticker on the pass side b-piller (where the striker is) that tells you what size the tire should be, what the pressure should be, and what the spare should be as well.
I could tell you a horror story about a dealership here in town that put Passenger tires on a 14 pass van. They overinflated the tires on it (what the door sticker said) it ended up rolling over due to a tire blowing out....it killed 12 people.[:'(][&o]
Tires aren't to be F'd with.
-Ivan
-Ivan
jwog666
12-27-2021 08:09 PM
