clutch
clutch
i got the motor out and rebuilt and im about to install the clutch and flywheel tonight. then bolt up the bell housing and tranny tonight. any1 have a step by step procedure for the flywheel and clutch? thanks gary
RE: clutch
Honestly, I just followed my Haynes and Chilton's...they have fairly good instructions. It is a very simple install. The FW bolts will only line up one way, so you can't mess that up. Be sure you put your block plate on first
I put my pilot bearing in after I put my FW on...be sure to put a little lithium grease around the edges to help it slide in or it may bind up on you.... The pressure plate lines up on the dowels on the FW, so snap it on and tighten all the bolts evenly so you don't warp the PP.
junior04
09-28-2015 10:53 AM
ccdguy
09-19-2015 05:20 PM
