Air Conditioner Issues
Old 06-30-2006, 03:45 PM
1911A1
1911A1's Avatar
Default RE: Air Conditioner Issues
It blows cold now all the time. Im guessing it just took awhile to get in the system. They checked for leaks and there were none and they also put dye in.
1911A1 is offline
Old 06-15-2007, 09:52 PM
daleclough
daleclough's Avatar
ORIGINAL: nacanitihs
ORIGINAL: All4n
ORIGINAL: PX429
You drive a Vert. Yank it out dropping some weight saving some gas and restoring horsepower. Drive with the top down.
no but seriously just buy a recharge kit from autozone there like twenty bucks
Its been proven that using A/C is more fuel efficient than having your windows down.
actually it is about the same mythbusters did a show on it. but you may need more than just one recharge can. i went to AUTOZONE and the kit was like $40 and it came w/ 2 large cans. try doing that. and a little can only does like 15% of a recharge so you just might need to add more cans
Did you conver from R-12 to R-134 or did Autozone sell you the R-12 recharge kit (and where can I get one)?
daleclough is offline
Old 06-15-2007, 10:07 PM
JZTRK
JZTRK's Avatar
91STANG Your problem is that you are low on freeon just get the right kind added and youl be fine
JZTRK is offline
Old 06-16-2007, 01:07 AM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Wow! A thread from almost a year ago! [&:]
PRO50SC is offline
Old 06-16-2007, 11:57 PM
LA95GT
LA95GT's Avatar
some times having too much freon can make not blow cold. Gotta make sure your pressures are right. sometimes you can luck up and just add some but a shop that knows what they`re doing can really get it blowing right
LA95GT is offline
Old 06-18-2007, 01:04 AM
BiggusJimbus
BiggusJimbus's Avatar
OK,
While on the AC subject...
I bought a '95 Cobra on Thursday night. Nice little car.
Driving up through Auburn (ca) on Friday, I realized the AC was FUBAR. So, I pulled in and got a recharge kit (134a) andput it on the system. The gauge tells me there is plenty of charge in there.
So, I'm looking at the compressor pulley, and as I'm MaxAC position from playing with the charge kit, It is cycling on and off every 5 or 6 seconds.
Do I have a failed compressor or some other trigger issue? Kragen had replacement compressors for 114 bucks. Wonder if that's a decent way to go, considering it may be a compressor problem.
Any ideas?
Thanks for your time.
Jim.
BiggusJimbus is offline
Old 06-18-2007, 02:28 AM
JZTRK
JZTRK's Avatar
That sounds like the pressure switch that energizes the clutch it would be on thepressure side line
JZTRK is offline
Old 06-18-2007, 11:42 AM
BiggusJimbus
Excellent. I'll look into that.
Is there a way to test for it? Can it behave this way if the pressure is too high?
I'll pick up a book, and get some guidance, but what would this item look like?
Thanks very much for your help.
Jim.
Old 06-18-2007, 05:15 PM
BiggusJimbus
Would this also be referred to as the "Pressure Cycling switch"? Looks like a twenty dollar part. That'd make me happy.
mtgldr
02-03-2024 09:00 PM
mapitts
05-15-2016 02:57 AM
04stangman
09-17-2015 01:45 PM
fastbackford351
09-12-2015 09:42 AM
09-01-2015 08:16 PM
Quick Reply: Air Conditioner Issues
