I went carb , but I have an AO
Old 06-21-2003, 05:59 AM
RAGNAROK
RAGNAROK's Avatar
Default I went carb , but I have an AO
I have an AOD tranny and I have started converting over to carb. What am i going to have to do to make my tranny work now? The dude at Advanced auto said Lokar makes a kit for it or something. Do I need this kit or will it work without having to do anything? And if it doesn't work why? They tell me it has to do with not using the computer anymore but I didn't really see any wires from the tranny other than the neutral saftey. Anyways I know I probably look stupid for asking this question but I need to know cause we are putting the carb and everything on tomorrow .</P>
RAGNAROK is offline
Old 06-23-2003, 09:16 AM
nostang
nostang's Avatar
You must have the throttle valve cable hooked up to the trans or it will burn up very quickly.The best bet would be to get a cable and bracket from the junk yard off of a carb equiped AOD.WARNING,don't drive it without the cable.The computer has nothing to do with an AOD,only on AOD-E's.It's very critical to get the cable adjusted properly after you get it installed,I would recomend taking it to a trans shop and letting them adjust it.Most of the people that I've seen trying to rig up a cable get real mad because they can't get it to shift right when they're done,that's why I would recomend getting all the brackets and arms off a junkyard car.Let me know how it turns out.</P>
nostang is offline
Old 06-23-2003, 01:30 PM
RAGNAROK
RAGNAROK's Avatar
OK thanks ,I'm glad someone answered because we are going to have it ready to drive by this friday. I can probably get the stuff easy. I hope this isn't a stupid question but the carb says it has a ford a/t kickdown something or another. Does that have anything to do with what you are talking about?
RAGNAROK is offline
Old 06-23-2003, 02:29 PM
nostang
nostang's Avatar
Nope,the kick down is for c-4's and c-6's,the kick down is on top of the throttle lever,you need the trans cable(also called the tv cable)to hook on to the bottom of the throttle lever,hope this helps.
nostang is offline
Old 06-23-2003, 03:17 PM
RAGNAROK
RAGNAROK's Avatar
Ok I was making sure. The guy at the auto parts store said Lokar makes a kit for this. I'll go talk to him about it after work. I think I might look into getting a C-4 anyways. The guy I bought the motor from had another nice motor and a C-4 for sale. maybe I'll give him a call since AOD's have a bad rep anyway , and all the B&amp;m shifters I have seen that I like either won't work with an AOD or require a kit. Whats your opinion on C-4 trannys? Alot of people I have talked to seem to like them more compaired to the AOD
RAGNAROK is offline
Old 06-23-2003, 03:29 PM
RAGNAROK
RAGNAROK's Avatar
Well i just went to Lokar's webpage trying to find the kit , and while checking to see how to cantact them I noticed that they are like a 15 minute drive away in my city hahaha.
RAGNAROK is offline
Old 06-26-2003, 07:58 PM
nostang
nostang's Avatar
a properly built aod should be about as strong as a built c-4,lentec is putting 900hp through aod-e's,and they are mostly the same inside.If I had a built small block,I would put in an aod and a 3500 stall converter and some low gears and have my cake and eat it too,good accell on launch and comfortable cruise rpm.
nostang is offline
bradleyb
11-27-2015 07:50 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
Sminemann
09-17-2015 09:24 AM
Daddys Girls GTs
09-14-2015 08:46 PM
jaiidutch
09-14-2015 10:29 AM
Quick Reply: I went carb , but I have an AO
