wipers issue
wipers issue
yesterday i went to use my wipers and the only way they would move was if i put them on the high setting and the creeped really slow so i shut them off. I'm thinking te motor is a little ceized up but it to windy to mess with it today i gotta wait til monday. I never drive this car in the rain so its like they will probaly never be used but i still would like them to work
RE: wipers issue
i just switched my motor fromt he same symptoms, the motor goes then it goes really really slow, then it fails...
first check the #18 fusable link, i'm pretty sure it's 18, it s a big solid metal one with two prongs, if thats loose or failing it may cause motor to act up. if thats working well, its possible the switch is going, but i'd bet on the motor...
had to replace the motor, there are 3 bolts mounting the motor to the firewall, also there are 2 electric connectors,first remove the wipers from the mounts on the hood, remove the grate and near the drivers side the motor mounts to the swing arms and you'll have to unclip the arms from the motor or unbolt the short arm from the motor, it's easier to unclip, just dont loose the clip, then you can remove from the firewall and replace with a new one, plug it in and bolt it up and be sure it works before putting everthing back together, should only take 1/2 hour...
RE: wipers issue
yeah i got out a hayes manual ( I love thier diagrams LOL) thier is a 6a fuse in #2 spot also i'll check my grounds someone told me tha tthe on on the wiper motor trans goes bad so i'mm check that too
RE: wipers issue
RE: wipers issue
Actually it raned here for like 2 days and my cover got shredded to a million part during heavy winds last week so it was out in the elements this week maybe thats what happened I'll give everything a good claening befre is go threw the wiring
lincolnshibuya
12-08-2015 04:37 PM
