Torque specs
RE: Torque specs
Torque Specs
always torque bolts in three equal increments
Bolts or Parts Lube or Sealer Torque to:
Main Caps Engine Oil 70 ft-lbs.
Outer Main Cap Bolts Engine 40 ft-lbs.
Connecting Rod 260, 289, 302
*289HP and Boss 302
Engine Oil 25 ft-lbs.
*45 ft-lbs.
Cylinder Heads
Engine oil
(blind hole)
Sealer
(water jacket)
70 ft-lbs.
Rocker Arms Engine Oil 20 ft-lbs.
Oil Pump Engine Oil 25 ft-lbs.
Oil Pan Engine Oil 15 ft-lbs.
Camshaft Thrust Plate Thread Locker 10 ft-lbs.
Cam Bolt (upper gear) Thread Locker 40 ft-lbs.
Front Cover Engine Oil 20 ft-lbs.
Intake Manifold
(Cast Iron Heads)
Non- Hardening Sealer 25 ft-lbs.
Valve Cover Engine Oil 10 ft-lbs.
Flexplate (Automatic)
Flywheel (Clutch)
Thread Locker 85 ft-lbs.
Clutch Pressure Plate Thread Locker 35 ft-lbs.
Centerbolt
(Harmonic Damper)
Thread Locker 90 ft-lbs.
Bellhousing
(Transmission to Block)
just thought I'd get them all out of the way
*289HP and Boss 302
*45 ft-lbs.
Cylinder Heads
Engine oil
(blind hole)
Sealer
(water jacket)
70 ft-lbs.
Intake Manifold
(Cast Iron Heads)
Flywheel (Clutch)
Centerbolt
(Harmonic Damper)
Bellhousing
RE: Torque specs
O I was defintelly listening to you. But my rotating assembly is a little beffier than a stock 302 and my rod bolts are 7/16 instead of 5/16 so i went with the 45 ft. lbs. It's all good I forgive you. (New kids) ha ha
LivingInThePast
09-16-2015 12:20 PM
