Whats the Difference?
Old 02-08-2007, 12:58 AM
  #21
africkanV6
africkanV6's Avatar
Default RE: Whats the Difference?
yea theres a clutch there for a reason lol. i always thought powershifting was jus keeping the gas pedal floored but still using the clutch and shifting as fast as u can.
africkanV6 is offline
Old 02-08-2007, 01:46 AM
  #22
wildsurfer92
wildsurfer92's Avatar
the t-5 tranny is a fully synchronized transmission, so with that said, you can drive it without having to use the clutch, and it does absolutely no damage to the transmission...thats how it was designed....now if you have messed up synchronizers then you cant do it. the only time you need the clutch is to start the car and get it into first gear
wildsurfer92 is offline
Old 02-08-2007, 01:55 AM
  #23
dimebag
dimebag's Avatar
wildsurfer92... no more talking out of you....ever...yes im serious
and ive always refered to shifting w. the clutch but not getting off the gas"flat shifting"
dimebag is offline
  #24
shaners90lxhatch
shaners90lxhatch's Avatar
^ it can be done harmlessly. The grind you hear when not executed properly IS bad. Break a left leg on a manual daily driver and you'll get it down. Dude your just letting theblocker rings scape agains the gears. Metal on metal is wear any way you slice it.
shaners90lxhatch is offline
Old 02-08-2007, 02:05 AM
  #25
94gtcoupe
94gtcoupe's Avatar
u sir are a moron... shifting with out the clutch will hurt syncros regardless, however if you matc hthe rpms it won't hurt them as much...
powershifting is not using the clutch to shift while your car is at WOT (common in drag cars with manuals)
speedshifting is using the clutch and shifting as fast as you can (if done correctly very LITTLE harm will come to the tranny)
and i rever to not lifting your foot for shifts while using the clutch as "no lift shifting"
here is an example of no lift shifting and yes i'm a "slow" shifter
http://s101.photobucket.com/albums/m...t=d6b55f5d.flv
ORIGINAL: wildsurfer92
94gtcoupe is offline
Old 02-08-2007, 02:10 AM
  #26
dimebag
dimebag's Avatar
ORIGINAL: 94gtcoupe
wont hurt as much, correct.. but still will hurt them(i realize this is what your saying... just pointing out that its a dumb *** idea... again)
dimebag is offline
Old 02-08-2007, 12:51 PM
  #27
FuzzyDiceRule
FuzzyDiceRule's Avatar
you just have to match the revs, like double clutching, my dad used to just wait when he was slowing down and at like 1.5k rpm, just slide it out of gear, no clutch
FuzzyDiceRule is offline
Old 02-08-2007, 01:41 PM
  #28
dimebag
dimebag's Avatar
yes i no you can do it... but it stresses the sycros.... its stupid.... but hey **** it, go ahead and do that...
dimebag is offline
Old 02-08-2007, 01:44 PM
  #29
dimebag
dimebag's Avatar
you can also shift w. no clutch if u really want to, or just tap the clutch and give it hell... but guess what... ****in stupid idea...
bottom line, if you like your mustang, and want ur tranny to work... dont shift w. out the clutch, wether it be matching rpms or not... dont ****in do it
dimebag is offline
Dokilar
15
10-16-2015 08:13 PM
breaking
10-02-2015 01:27 PM
UrS4
09-30-2015 10:13 AM
mrappe
09-26-2015 10:16 AM
Quick Reply: Whats the Difference?
