warm/cold doestn matter
RE: warm/cold doestn matter
ORIGINAL: silver91gt
test the voltage between the green and black wires(, or ground) key on engine off
should be around 0.98volts
yeah if you can get it to .999 you will be set you want it as close to one but right under as you can get
but after you do this you will have to adjust your idle because it will idle higher once you adjust it closer
jessicarabbit
09-25-2015 12:41 PM
