Routing Belt after smog pump i
Old 08-02-2003, 10:52 PM
TMartin409
TMartin409's Avatar
Default Routing Belt after smog pump i
How do you route your belt after the pump is gone and what is the new belt size?
TMartin409 is offline
Old 08-03-2003, 12:39 AM
Buzzstang
Buzzstang's Avatar
the belt is routed the same the size? it been so long since i removed mine i have forgoten. i will check
Buzzstang is offline
Old 08-17-2003, 08:41 PM
1982gt
1982gt's Avatar
run it EXACTLY as you would with the pump...just dont put the belt on the smog pump... go right over it...you may need a shorter belt though
1982gt is offline
Old 08-17-2003, 10:22 PM
vfast
I ♥ Acer
vfast's Avatar
I have a smog pump delet kit
vfast is offline
Old 08-17-2003, 11:04 PM
Buzzstang
Buzzstang's Avatar
yeah i have one of those. they are nice. if you take the smog pump off then take a string and run it the route the belt usually goes and then measure it. that is close to what size belt you need.
Old 08-19-2003, 01:14 PM
vfast
I ♥ Acer
vfast's Avatar
I have one for sale!!!
vfast is offline
jwog666
12-27-2021 08:09 PM
Bokeo
10-10-2015 08:28 PM
Teddi
09-29-2015 12:24 PM
mrappe
09-26-2015 10:16 AM
Quick Reply: Routing Belt after smog pump i
