Need Help, Weird Idle Problem.
Old 02-20-2007, 07:41 PM
Mendez33
Mendez33's Avatar
Default Need Help, Weird Idle Problem.
I started having a bad surging idle problem. The idle would jump up to 2,000 RPM and stay there. I decided to take off the IAC and clean it out. Well after I did that, the car wouldn't stay running. Just by cleaning the IAC, the idle dropped ?????. So nextI decided to try and reset the base idle by disconnecting the battery and the wire that goes to the IAC. After I got the idle straightened out, I tried to reconnect the wire to the IAC and the idle jumped back up to 2,000 RPM. Why will the car run so good with the wire to the IAC disconnected? Does this sound like a TPS problem?
Mendez33 is offline
Old 02-20-2007, 08:34 PM
Joel5.0
Joel5.0's Avatar
Default RE: Need Help, Weird Idle Problem.
Run the KOEO/KOER selftests and check for any failure codes first.
Joel5.0 is offline
Old 02-21-2007, 03:51 AM
Mendez33
Mendez33's Avatar
Thanks for the link Joel. I noticed your from P.R. Both of my parents are from Utuado.
Mendez33 is offline
4cylinderplus2
10-09-2020 07:45 PM
TCStangerv6
10-11-2015 05:57 PM
svfetter
10-05-2015 11:39 AM
69Volunteer
09-30-2015 10:39 AM
mungodrums
09-28-2015 10:54 PM
Quick Reply: Need Help, Weird Idle Problem.
