notched block for 331?
Old 03-02-2007, 02:08 PM
1bad91
1bad91's Avatar
Default notched block for 331?
I woundering if i would have to notch my block to install a 331 stroker kit. I know a 347 has to but i heard because of the shorter stroke of a 331 that i wont need to. Any info would be appreciated
1bad91 is offline
Old 03-02-2007, 02:21 PM
luckythirteen13
luckythirteen13's Avatar
Default RE: notched block for 331?
i think it depends on the rods used. i put h beam rods into my new motor and i had to notch the block a little
luckythirteen13 is offline
Old 03-02-2007, 02:24 PM
fordstroker
I ♥ Acer
fordstroker's Avatar
using a nut and bolt rod you should be fine, using a cap screw rod you ore than likely wont have the needed .060-.070 thou clearance between the rod bolt and cylinder. Just mock it up, put the crank in torqued down, put 1 rod on, no piston and rotate and use feeler gauges to make sure you have the above mentioned clearance
fordstroker is offline
Old 03-02-2007, 02:25 PM
1bad91
1bad91's Avatar
mine are I beam
1bad91 is offline
Old 03-02-2007, 03:01 PM
fordstroker
I ♥ Acer
ORIGINAL: 1bad91
mine are I beam
like I said, I-beam come in 2 forms, nut and bolt and capscrew
Old 03-02-2007, 03:02 PM
mypony89
mypony89's Avatar
Stupid question 101 - whats notching a block?
mypony89 is offline
Old 03-02-2007, 03:14 PM
fordstroker
I ♥ Acer
ORIGINAL: mypony89
you need to notch the bottom of the bores when stroking a 289-302, the rod bolts will hit the bores.
Old 03-02-2007, 03:18 PM
mypony89
mypony89's Avatar
Thank you
mypony89 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
mustangheaven
01-03-2016 11:20 AM
Matt's 95 Stang
10-05-2015 07:16 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
mustangheaven
09-29-2015 11:00 AM
Quick Reply: notched block for 331?
