Alternator questions on a 351 conversion
Old 03-03-2007, 11:48 PM
lookin4astang
lookin4astang's Avatar
Default Alternator questions on a 351 conversion
Ok I picked up my 87 today and decided to make the 1 hr trip home driving it instead of towing it. Well, I got about half way back and realized the voltage gauge was pegged in the red (low). Well, the car started backfiring when I tried to get into the throttle so I finally pulled over and shut it down.
I got a friend to come pick me up and we towed it the rest of the way home. I stopped in and picked up a battery and alternator on the way home. Keep in mind this car was converted to a carbe'd 351. Well, after replacing all that stuff, the car STILL doesn't charge at all. The only thing the guage shows is what the battery has in it so it's barely above the red line.
Well, I got to thinking about it and realized that the alternator we got to replace the one on the car is for a Fuel Injected 351 cause that is what was on it. It uses the factory wiring harness which in my case now is no good. I didn't think about the fact that it wouldn't work. So here is the question.
What do I need to do to convert the alternator wiring over to work with my carbureted 351? If anyone can go into detail I'd GREATLY appreciate it. I havent even got to play with this beast yet.
lookin4astang is offline
Old 03-04-2007, 12:55 PM
notchback50
notchback50's Avatar
Default RE: Alternator questions on a 351 conversion
you can probably just get a one wire alternator and just use one big wire cable.
notchback50 is offline
Old 03-04-2007, 01:49 PM
lookin4astang
Well, I got a wiring diagram today for it and it is showing using the stock alternator. The guy told me to trace the wiring down and check all the fusible links. The wiring is kind of a mess, so I may wind up ripping it all out and rewiring everything. But hopefully I can figure it out. More suggestions?
Old 03-04-2007, 06:01 PM
PONY GUY
PONY GUY's Avatar
I got a GM (yes thats right) 1 wire alt and used 4guage wire toto the solinoid and it works good I'm gonna upgrade to a 120amp becuase I have under drive pulleis electric fan and water pump and a 140 gph fuel pump
PONY GUY is offline
Old 03-04-2007, 09:23 PM
lookin4astang
So if the car is carbed it doesnt need all the extra wires that are on the stock harness? I got like 4 wires goin to the alt right now. Does the voltage gauge wire up to the solenoid as well?
Old 03-04-2007, 09:25 PM
lookin4astang
Here is a pic of the engine and the alternator I'm using....
Old 03-04-2007, 09:29 PM
PONY GUY
PONY GUY's Avatar
was this car origionaly Fuel Injected???? I would just get a GM 1 wire with a internal voltage regulator and be done with it
PONY GUY is offline
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
11-10-2015 11:39 AM
Golfsito
10-06-2015 11:02 AM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
Quick Reply: Alternator questions on a 351 conversion
